Greetings,
Hopefully some of the Jaguar greats can answer some of this as I have searched but drawn blanks at every turn.
I am in the market for a wiring harness (passenger compartment, LHD) for a 2011 XKR coupe.
Question: Will a standard XK harness work?
What years should work?
Do the part numbers have to match exactly?
Lastly does anyone know/have a source?
Thank you in advance.
I checked JEPC and it looked as if this was going to be a lot easier than I'd first thought on reading your post. It looked like a simple change at VIN B32753:
However, it then starts to get a lot more complicated. The actual harness used depends on vehicle equipment specification:
For a straighforward harness swap, matching P/N's are going to be essential but you could possibly modify one of the other harness options using sections of the existing.
This theory sounds plausible but I'm not sure I'd want to put it into practice myself and the result would be a real Frankenstein!
Thank you for your reply. Im a glutton for punishment apparently!. Its a flood vehicle and i have a ton of servicable modules for it already and some new fuse boxes (although I need the passenger compartment one) so im trying to.get around cleaning all the harness ends and possibly repairing/repinning some of the ones in the worst condition.
I don't seem to be able to find one through Jaguar... any sources where one might find the correct one? Thanks again.
You might want to try SNG Barrett. I'm not sure of the spelling, but they are a registered vendor so check them out in the vendor section. I think they give a 10% discount to Forum members.
I just want to take the time to say thank you guys very much for taking the time to try to help me sort this out. I very much appreciate it!
