2011 XKR Hesitation at 1500 RPM
Thanks in advance for the thoughts. 2011 XKR with about 20k miles. Just started having a very noticeable acceleration hesitation at 1500 rpms. No codes and nothing else out of the ordinary? I'll probably throw in some Techron fuel cleaner for starters. Any thoughts?
[QUOTE=RocketViper;2115085]Thanks in advance for the thoughts. 2011 XKR with about 20k miles. Just started having a very noticeable acceleration hesitation at 1500 rpms. No codes and nothing else out of the ordinary? I'll probably throw in some Techron fuel cleaner for starters. Any thoughts?[/QUOTEi]
so has the issue been solved? I have an XJ 5.0 SC with the exact same issue you described. I tried changing the fuel filter, transmission fluid and filter, and intake hose. Still the issue persists.
would appreciate your feedback!
Throttle body was cleaned, in fact. Can you clarify the system reset and “italian” tuneup?
it is increasingly annoying for me as, amongst over a dozen cars that I’ve owned over the years, this is by far the car I love the most.
Received 1,177 Likes
1 disconnect the battery
2 touch negative and positive cable together to discharge and charged component
3 reconnect battery
4. DRIVE her so she can relearn your preferences. At least 16 kms.
(see the section “Changing the vehicle battery” in your owners manual. It describes the process of resetting some components)
3 reconnect battery
Kellysue (03-06-2022)
BigMikeATL
02-20-2018 06:56 AM
mhamilton
10-15-2017 06:33 PM
