2011 XKR Metal Clanking from Engine
Hi guys,
Before I take my cat to the mechanic and spend big $$$ maybe you can help me... my car has 70k miles, and in last few days I noticed strange noise coming from engine, while running, tried cold start, warm it up, A/C on/off, turning wheel while engine running, but the noise stays the same. I decided to stop driving it to prevent any damage.
here is video sample of the noise.
Thank you!, I'm sure it will take me longer to find needed tools in my step-father's garage than to fix the engine !
Hello Peter,
Sounds very similar to the prroblem I had with my 2010 XKR - turned out to be the notorious water pump bearing failure (( could see the pulley wobbling really badly when the noise started - the car had only covered 34,000 miles at the time). Stand on the right hand side of the car and look between the hoses - you should be able to see the water pump pulley.with engine running Sometimes these noises, although very frightening, can turn out to be something external. Good luck !
Watch this thread on removing the S/C. Videos are excellent.
https://www.jaguarforums.com/forum/x...thread-248243/
1 of 19 (07-23-2021)
Here is update guys, It turned out that the water pump was making that noise, the pulley seems to be loose and hitting the engine block although it was not leaking coolant..... i don't think it can be tightened as there is only one bolt on the water pump pulley, correct me if I'm wrong .....
Im located in USA, where should i get water pump from?
should i go with OEM or aftermarket?
anything else should I order or replaced while I'm there?
Thank you !
Thank you !
Thank you !
Thank you !
Here is your part:
https://parts.harperjaguar.com/oem-p...embly-aj813909
The local dealer was ridiculous, so I bought my mirror cover from this same dealer. Shipping was fast and had no issues. I was a bit leary about buying online, but they came through great!
Looks like you can get OEM for about $200-$250. I'd go that route. Kind of crazy considering I spent $380 on a damn small piece of plastic interior trim piece...
Here is your part:
Here is your part:
You are having 5.0 s/c, correct? If it's early model you will have a longer list of parts to replace assuming you want to have the latest iteration of a water pump.
For sure you need these two:
- C2Z18658
- AJ811539
As far as I remember upgrade/update of water system requires:
- C2Z26930
- LR049989 (cannot find Jag number, but this one is the same as in Jag)
Also changing thermostat to water pump hose might not be a stupid thing (again LR code: LR033994)
Hope it helps.
- C2Z18658
- AJ811539
- C2Z26930
Hope it helps.
- C2Z18658
- AJ811539
- C2Z26930
Hope it helps.
- C2Z18658
- AJ811539
- C2Z26930
Hope it helps.
Man, this is getting more and more expensive lol
thank you for recommendations
I just saw this thread and was going to suggest the water pump because I had a similar but even more pronounced noise coming from mine several years ago and was sure it was coming from the supercharger, but it turned out the water pump was wobbling so much it was knocking on the engine. But don't think you're done, I've had five water pumps on my 2010 XKR.
