2012 XK exhaust modification
Hello all, new to this forum and sure this topic has been covered, but. Thinking of changing the stock exhaust system to a quicksilver super sports. My XK is a base model and I understand I will need to change a body part (lower extension?) to make room for the quad tips. Can anyone confirm that the part I will need is "C2P16656XXX" ? Will this just bolt on without any mods when I replace the stock one? Thanks Ron
There are a lot of threads on this subject. I own an XK and wanted the Mina Gallery exhaust. However, after removing my resonator and installing an X pipe I'm quite happy with my exhause tone. Your XKR has two resonators. Perhaps removing both resonators, fuse 19 and installing either a X-pipe or an H-pipe my give you an acceptable exhaust tone. Either way, these modifications would only enhance an aftermarket exhaust.
The following 3 users liked this post by Wm. Lyon:
Received 2,012 Likes
Niiiiiiiiiccceee. Small diameter compression bends. Looks fantastic! I think I'll redo my mandrel bends with compression. Coolest thing I've seen all morning.
Maybe dude didn't want to buy a different valance so he faked the inners? Like kj, I don't get the reason for valves, unless what was there was 'reutilized'.
mattastic13 (03-19-2023)
Thanks to @Wm. Lyon , had a X pipe thrown on at a local shop and it is sounding awesome. I'll be pulling Fuse 19 shortly as well.
cft080
02-08-2013 07:07 AM
