2012 XKR: Cold Start Idle "Ticking"
After I had my Timing Chain Tensioners replaced due to a startup chatter back in July the Jag started great... Then around September on cold startup I thought I heard a noticable Ticking noise after the initial Vroooommmmm of the startup when it would idle down to about 500 rpm. Tick Tick Tick Tick loud. After driving the car for 3-4 minutes the tick would no longer be noticeable. If you restart the car when its warm it stays gone. Its just when its cold. Anyone have any idea? Tried to post some .m4a files but the site said the file attachments were invalid?
Anyone got a clue?
Loth
Anyone got a clue?
Loth
Loth,
A clue - from my previous post #2 in this thread: https://www.jaguarforums.com/forum/x...tartup-151807/
The ticking noise is probably caused by the fuel injectors and/or one or more valves out of adjustment. Have your dealer diagnose and repair it before your warranty expires. See: http:// https://www.jaguarforums.com/...get-rid-89466/
Does it make any difference if the AC compressor is engaged or disengaged? Does the speed of the ticking vary with the engine rpms? Does the engine run smooth or rough when you hear it ticking? Try listening better with the windows down and the hood open. Could it be the exhaust system heating up and making noise from expanding metal?
Too many possibilities, and I'd want to know the cause in case it could cause damage if ignored for too long. I'd take in in to the dealer to make sure it isn't a ticking time bomb, metaphorically speaking, of course.
Stuart
Stuart
The tick seems to be audible just after the car settles down after initial startup to the 500rpm... the tick is in time with the engine tick tick tick tick sound like its coming from top of engine or front of the car - hard to tell. Does not seem to effected by Air Conditioning being on or off. revving the engine does not seem to make it get louder however but hard to tell wheny our in the car. Talked to 2 people in the know so far.. they do not know for sure what it could be.
This morning I started the car up and there was no ticking. It was super cold start in the morning after 2 days no start. Sounded great for 3-4 min. Then I looked in the cabin and saw the climate control was set to auto and it was warmer in the car then outside so not much was happening. I set the climate control to LO and slowly i started to get the tick.
BUT... then i turned it off and the engine was ticking. Then before shutting car down put it back to original settings and turned the car off. Waited a few minutes. Turned the car back on and it ticked.
Ugh... I have no idea if I found a variable or not. UGH
Loth
Loth
Loth
Loth
You said it was super cold and it didn't tick when you first started it, and when you turned it off it the engine was ticking. That sounds like metal expansion noise, and not reciprocating engine noise, to me since it was ticking when the engine wasn't running. Most likely suspect: one or both catalytic converters expanding internally as they warm up.
Maybe you didn't notice that your Timex fell under your seat. "Takes a licking but keeps on ticking"
Stuart
Loth
Loth
just an FYI. After giving the dealership my car on 11/12/15 was contacted a few days ago by one of their best techs. They state they were never able to isolate why the engine was ticking per say but that Jaguar ordered them to replace all 4 Variable Valve Timing units on the car (12 XKR with 27,000 miles). We will see if this works?
The Tick occurred under the following conditions:
1- Cold start let it idle down to 500rpm and wait 4-5 min and it would start ticking.
2- Drive it for 5 minutes and it would stop and stay stopped...but turn it off for a few minutes but still start warm and immediate ticking at idle (500 rpm).
Dag on weirdest thing ever and they had never heard of this problem before and neither had Jaguar. Doh!!!
Tick from engine
Hi,
Same here, my 2013xkr has the exact same and is at the dealership as we speak, I have 5 days of warranty left.
When I start the car from cold in the garage I drop the windows and listen to the engine, at cold the engine stays at 1000rpm then after a few seconds I here the slight whir and then the engine drops to a steady 500rpm idle ............. With the tick, tick,tick, in time with the revolutions of the engine. Very similar to and it could be a faulty hydraulic tappet. Give the car a bit of throttle down the road and it's gone, but definitely should not be ticking at cold start.
The dealership had it in a few weeks back with the same complaint and fitted a supercharger kit, but it hasn't fixed the problem. When the dealership did the work I managed to travel 30 kms before the car "low coolant "light came on, I pulled over and got enveloped in steam!!!!!!!
Needless to say it had to get a tilt tray ride back to the dealership . Either they hadn't bled the coolant system, or left a hose clip loose, but I was very lucky to not have warped heads. I wrote to Jaguar UK and AU voicing my concern just in case I have a problem in the future with this engine due to work carried out be one of their trusted dealerships.
To say I was not happy would be an understatement, that and the fact I also adopted a few scratches on the top of my driver side wing, they said it wasn't done whilst doing the supercharger and I can't prove they did it, but it definitely wasn't there before, I know every millimetre of this car as I polish it at least once a week, those of you who have the same regime will know where I'm coming from, the car is not perfect, but I know what marks were there and the ones that were not.
I'll update further when I get the car back regarding the tick.
They are also investigating a flickering infotainment screen when the lights are on and driving at night.
I fitted Red stuff front & rear brake pads myself & flushed the brake fluid, the result. Good braking bite and a very small squeak from one rear calipers, that I'm hoping will disappeared when they have bed in, if not I'll apply more Bendigo grease.
Lothar52 (07-13-2016)
Hi,
My dealership took the oil filter out and checked it...no debris. This is how my car was fixed-
1- THEY REPLACED THE TIMING CHAIN
2- THEY REPLACED ALL 4 ACTUATORS - VERY IMPORTANT - THIS IS WHERE THE TICKING IS COMING FROM!!! ONE OF THE ACTUATOR IS BAD AND NOBODY IS GONNA KNOW WHICH! SO REPLACE ALL 4 (700 bucks for 1 not under warranty - LUCKY YOU!!)
3- THEY REPLACED THE TIMING CHAIN TENSIONERS
4- THEY RE-TIMED THE ENGINE.
1000% FIXED!!!!
CALL THEM NOW. The V8 engine EATS these chains. You replace those parts and it aint gonna tick no more!.
The engine had to be dropped - basically the car elevated over top of it.
WATER PUMP- . While they had my car apart they noticed for the 3rd time my water pump leaking. They replaced the pump AND THE STUB PIPE.. Very important they need to replace the other components as well not "just the pump". OR ITS GONNA LEAK AGAIN!!!
FEEL FREE TO PRINT THIS OFF.... THESE V8's EAT THE TIMING CHAINS... REMEMBER THAT! More frequent OIL CHANGES - 4000-5000 miles not 10,000.
Loth
5.0sc engine tick at idle
Hi guys,
My 5.0sc came back home with the same ticking noise, my dealer is now contacting Jaguar armed with write ups from other forum members who have had the same issue, this should enable the correct repair to be done and make my Jaguar engine sound like a Jaguar, not a 1980 2.)ltr ford Cortina (not that I have anything against Ford Cortina's) just using the noise as a comparison.
Jaguar has known of this problem for over 3 years and if reported I think they get on and fix the problem.
A timing chain and a few engine parts is better marketing than a unhappy customer, especially with the cost involved to purchase one of these beauties.
Let's hope It gets put right.
Lothar : to make this clear: it applies only to the 5 litre engines. The 4.2 litre engines do not have this issue (or any other issues!). The 4.2 V8 may be the best engine Jaguar has made yet.
2013 Jaguar XKR 5.0 sc engine tick
Ok, new update.
Over the last two months the car has been back and forth to the dealership to try and diagnose the engine tick/rattle at cold start. The technicians at first could not hear the tick due to road noise outside the front of the dealership, even though the workshop is tucked around the back it still has background noise from the road that makes it difficult to hear slight ticking/rattle noises. I also handed in phone videos of the noise taken in my garage and also posted these to CJC Australia for their opinion.
The service manager came to my house at 7am one morning and we started the car in my garage from cold and we both video'd the sound and sure enough, there it was a lovely crisp ticking.
My car has now been at the dealer for two weeks for further diagnostics & testing, a tech from Jaguar Australia has been there for the last two days and the verdict is....... vvt problem.
They disconnected the vvt's and the sound disappeared, the dealer tech contacted me to keep me informed and said that it could be possible that the timing chains and tensioner could also be replaced when they take the front end off the engine to replace the faulty vvt's.
It looks like I'll have the car back for a couple of weeks while the parts are on order, but I look forward to a nice quiet start up from cold, can't wait.
