2012 XKR: Cold Start Idle "Ticking"
Old 09-10-2019, 01:58 PM
George05's Avatar
Originally Posted by Queen and Country
Here is a video of mine, I know you have another engine right there to compare with, but just trying to help since your original video saved my butt. (btw, my first video ever, excuse the pic quality- audio should be superb, recorded on very good mic on phone)
Completely cold start (not started in 4 days)
50k miles on the engine
In garage, left the sound of the hood closing at the end as a volume reference.
Phone was on tripod, so any shake you see is me getting in the car, no vibration from the engine.
Note engine cover off so as not to muffle any sounds.
https://youtu.be/8coqXOq72X8
My engine sounds same as yours but dont have clunking noise at end
  #82
Old 09-10-2019, 03:31 PM
George05's Avatar
This is what it sounds like going down the road.
https://youtu.be/6lsLWNs0MVE
Sounds like a motorbike
Queen and Country (09-10-2019)
  #83
Old 09-10-2019, 07:55 PM
Queen and Country's Avatar
Received 2,383 Likes on 1,609 Posts
Originally Posted by Lothar52
I wonder if I should do this myself?
Without doubt. It really works and you have only something to gain, regardless of problems, you need to do this. Ask another forum member Pwpacp.
Are you changing the oil yourself now. I can show you some very inexpensive, Jaguar approved oil to do the cleaning so that you are spending much.
  #84
Old 09-10-2019, 07:59 PM
Interesting.
Mind you had not been run in 4 days and then just run for the length of time you see in the video. Which is actually a pretty bad thing to do.
George05 (09-11-2019)
  #85
Old 09-11-2019, 05:35 AM
u102768's Avatar
Received 1,490 Likes on 908 Posts
I really didn't hear my knock in your video Q&C... your sounded totally different to me? u102 does your sound like mine or his?
Q&C's.
I posted a recording of mine in a different thread:
https://www.jaguarforums.com/forum/x...7/#post2117641
  #86
Old 09-11-2019, 10:10 AM
u102768,
If leisure permits, do another recording from crank to shutdown. So that we can get a time reference.
I do not hear a problem in yours just listening over the computer speakers, will put on headphones later. I am really wanting to learn the sound you and your mechanic describe, so I can identify it myself.
  #87
Old 09-11-2019, 01:51 PM
guy's Avatar
guy
guy is offline
Received 1,103 Likes on 776 Posts
Q&C, I love the fact you were driving in the slush!
  #88
Old 09-16-2019, 04:02 AM
u102768's Avatar
u102768,
Finally managed to take a video. It isn't as clear as yours and may be best listened to through headphones but you can hopefully hear the ratchet sound that I noticed in yours stop and start as the revs drop between 1:03 and 1:06 then as I take the gearbox out of drive at 1:14, 1:27, 1:42, 1:58, 2:10 etc. I also raise the revs at around 3:25 and the ratchet noise gets quite loud then stops and starts as the revs drop and comes and goes quite a bit until I stop the video.
The sound is no where near as noticeable once the engine was fully warmed up after a 20 minute drive:
The following 2 users liked this post by u102768:
Lothar52 (05-22-2024), Queen and Country (09-16-2019)
  #89
Old 09-16-2019, 12:36 PM
u102768.
I see what you mean.
I suggest you do nothing mechanically until there is more clearer indication of what it is. No I am not using you as a Guinea pig. Were mine a couple of years younger than yours or lower mileage, it might have worked.
You know your way around an engine to know that there is no additional penalty if the part you suspect fails but there is a price to be paid if your guess is wrong.
There is a data point you might find of interest. 4 days prior to the video I posted, I started the car for the first time in 4months. And that was to meet a visiting forum member for lunch. (yes that's how redundant its becoming in this neck of the woods, and you dont realize how well you have it made in OZ, its the ideal country for it, parts unavailability not withstanding)
The car misfired for the first 5 minutes.
Then it cleared up.
Cobweb in mass sensor, unlikely, fuel varnishing, most likely, the clearing up was the clue.
You too mentioned it clears after a while.
Why not try to do an injector and oil pathway clean.
Its far more pronounced in yours, to the point that its made me notice it faintly in my recording.
u102768 (09-17-2019)
  #90
Old 09-16-2019, 03:02 PM
George05's Avatar
Mine asked for a drink of oil today so put in 250ml to keep it happy as i am currently running through the second of six tank fulls of injector cleaner then will do an oil change as suggested by Q & C
  #91
Old 09-17-2019, 04:23 AM
MH3.0D's Avatar
An update on my noise on the XFR-S.
Took it back to the dealer and I pointed them to the high pressure fuel pump covers and asked if they had been re-installed correctly after the recent work on the engine (8 exhaust tappets right bank, both cam timing chains, guides and tensioners). Car was returned significantly quieter but the service adviser could not tell me what was done precisely.
There was still some residual noise at cold start but significantly better than previously.
Took the car for a second opinion to my usual mechanic and we added some Archoil oil additive AR9100 to the recent dealer fresh oil (I have used this in all my cars since 2008). This quietened the engine almost immediately and from this point on, the noise during cold start is acceptable and after warm, the engine runs beautifully.
To be sure, I dropped in to Mike Roddy Jaguar in Moorabbin, VIC, Aust. and he had a listen. His response is that these engines are inherently noisy but that mine is the quietest one he has heard to date. He also suggested that the level of power from the engine with the factory spec oil is not usable (traction issues) in everyday driving, so he suggested I try a slightly thicker engine oil, a 0W30. I am going to give that a try shortly (AMSOIL 0W30 with specs that exceed Jaguar spec oil), plus add the Archoil oil treatment and see how I feel about the engine running thereafter.
I am also an avid fan of the Archoil Fuel treatment to maintain the injectors. Been using it for the same period of time (one bottle for a full tank twice per year) across several manufacturers and models without every having issues with injectors. This is not an advertisement, just saying I found a product that works for me.
ralphwg (09-17-2019)
  #92
Old 12-14-2019, 06:00 PM
toronadomike's Avatar
I have the same ticking noise that stays in time with the engine rpm on cold starts, and disappears after driving 4 or 5 miles. The noise seems louder in the winter and still disappears when the engine warms up. My stethoscope shows it to be the loudest on the valve cover bolts near the back of the engine, and the noise is similar to a worn hydraulic lifter (of course it is Not). This is my 1999 XJR with a 2002 XJR supercharged 4.0, and no VVTs on this model. The timing chains and tensioners were all New with the engine swap. I left this 1999 XJR with the Jag Dealer overnight, and they heard the same ticking on the cold start - and offered no suggestions as to what the noise is, but offered to install New cylinder heads. I like the idea that it might be a fuel injector - or is that just wishful thinking?
Thank you,
Mike
  #93
Old 12-14-2019, 06:07 PM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
You are in the wrong forum. This forum is for X150's and you are discussing X100s and similar year other models. Hopefully a moderator will come around and steer you in the correct direction.
  #94
Old 05-22-2024, 06:46 PM
Lothar52's Avatar
This post brings back memories. Someone messaged me today regarding my recording of this ticking issue and if I still had the files…but unfortunately I do not.
i still have ticking that drives me nuts after they replaced my VVT’s it eventually came back. It is what it is but it’s slightly different now….
dealership says it’s the injectors…. I heard it in one of those videos above right before they turned the engine off.
  #95
Old 05-23-2024, 03:10 AM
guy's Avatar
guy
guy is offline
LOL, you should hear the high pressure fuel pump on my LR4, SCV6.
  #96
Old 05-23-2024, 09:54 AM
Lothar52's Avatar
I want to hear it, can you take a video of it and upload it to YouTube and put a link for us here? It would be good to confirm that tick.
Loth
SeanU
10-24-2015 04:57 PM
hen555
07-28-2015 06:29 PM
vorkragresh
01-17-2015 07:34 PM
vorkragresh
01-13-2015 09:48 AM
Faldo
01-01-2009 08:41 AM
Quick Reply: 2012 XKR: Cold Start Idle "Ticking"
