2012 XKR convertible need advice head gasket or motor?
Hi everybody I'm throwing this out there could use some advice on a 2012 black XKR with about 90,000 miles on it it's a convertible beautiful condition and sitting in my driveway for approximately a year bought it at auction and found out after the fact that the oil was milky car would start and then up after a few minutes the smoke from the tailpipe would turn white and then it would stall out. I am mechanically inclined but not to that level after some investigation I feel that it's a head gasket from the milky oil. I live in the Northeast in New York City could use some advice as I'd like to keep the car it's beautiful condition can use the mechanic to either fix the engine or possibly replace don't know which direction to go to and who to ask who has experience. It's a supercharged 5 litre seems to be the same engine from the range rovers so I'm not sure if that's possible to use one of those engines or just to get somebody to fix this one while it's sitting in my driveway.
Originally when I bought the car I thought it was just a coolant leak because there was a cracked hose on the back of the engine right near the firewall that was kind of a u-shape look like it came out of one side of the engine and then went back in I was able to replace that with a new part and then put coolant in it and that's when it started to shut down seem like the water was flowing into cylinders making it choke. I kept having to add coolant to the reservoir and that some point look like the water was coming out of the tailpipe.
Assume it is is the head gaskets, and open up the motor. Once inside judge the condition of the cylinders. Probably send the heads out for rebuild.
Check the shaft in the turbo for bearing wear Then close it up, and all should be all right. Check the wastegate is operating well. Qualified mechanic is needed incase there are other complications.
Personally because of the computer's system complexities, I would do a top overhaul instead of a switch. The price of buying a second engine with a few thou fewer miles, could equal the total price of the existing engine overhaul. Costs would be gasket kit, 2 heads overhauled, new turbo bearings, and a good mature mechanic that can estimate his time. All that, plus 30% incase of problems $.
Received 1,172 Likes
And that's where we will have to agree to disagree.
In some cases, I am all about outsourcing. And quality typically costs a little more. Of course the value is ownership and responsibility of the fix.
There are some good shops in upper NY state and the shipping of a car is not expensive.
(But it doesn't look like the Triumph (TR4A??) can take on the responsibilities of a daily driver yet??)
As @sony2000 mentions, I'd go the rebuild path myself too. (In fact I have a few times and have always been happy with the results)
Don't have a garage but I have a backyard and a front yard that I can put a tent over it before it gets cold here in the Northeast. wonder how long it would take to do the job?
And yes that is a triumph tr4a with rare independent suspension sitting next to it that needs restoration my dad bought it to restore it . Purchase some Italian parts but never got to do any work to it so it's now going to look for a buyer if anybody's interested . maybe even swap it for the work on the Jag .
Rare independent suspension
Looking for a buyer if anybody wants or for work on the jag XKR
It's a 1966
It's a 1966
guy (Today)
Abby's Guy
04-23-2014 01:28 AM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
