When I fill the screenwash on my 5.0 xkr instead of the filler tube filling to the brim it overflows at a much lower level all over the floor. This is my first x150- is this normal or was my car built on the Friday afternoon shift?
I too have an 2012 XKR with the same issue... dropped it off at my indy yesterday for that and various fluid changes. I don't expect to hear back from him until possibly Monday and will let you know what the issue was.
When I look a the part- #C2P21376, the only leak points are through the fittings the pumps go through the tank or the fluid level sensor through point. They are all very low in the tank. If your tank fills more than about 1/4 full and then leaks, it may have a crack in the tank.
Mine fills to the brim with no leaks, always ensure I do it before I go in for a service so they'll not charge me £3 for screen wash top-up....tight git that I am
On taking the filler neck out (this whole job was done from the top, saving wheel and arch liner removal) the original seal had been crushed by the factory on 'fitting' and looks like it has leaked from day 1. The seal was just over £2 from jaguar and fitting was easy from the top- I used a touch of silicon spray on the new seal and pushed it into place using the handle end of a screwdriver- if you had small hands you could just about get them into the recess. About 10 minutes start to finish.
Thanks for the help
