I have totally exhausted all avenues in an attempt to purchase a service manual for 2013-2015 XK. I understand that you can download it from Jaguars Topix site but I have read that it can take days to download it, just don't have that kind of time. If anyone has the manual I would be more than willing to pay you for your time for a copy. Thanks for any assistance.
Thanks. I have downloaded the 2012 XK Shop Manual that Gus posted but the manual covers up to a certain VIN which is below mine. You are correct as it covers 90% of what is needed. But in my case I was looking on how to change out the front turn signal bulb and what is covered does not match the headlight that I have. They must have changed out their headlight design for the later VINS.
The 2012-2015 MY are all the same. They never made an update to the 2010 MY manual so the slight body changes like the headlights haven't been updated. As for changing the headlight bulbs you need to remove the headlight assembly from the car . The 3 screws are in the same location as the 2010-2011 MY but there is no washer hose to disconnect. I bought a DVD on Ebay a few years back and it has all of the issues that one needs to do complete repair of the car.
jagtoes - attached is a picture of the rear of my style headlight assembly. The multipin connector is the only access to the turn signal. I can unlock it but it will not come out, it can be pushed easily and I'm afraid that it might drop in and then I'd really be SOL. Any suggestion on how this operates. Thanks
Have a look in the stickies section 2007+XKR 'HOW TO' quick links post #3 for many technical documents including a 2010-2015 MY XK Workshop manual from VIN B32753. Unfortunately I don't think it provides any help with your issue.
Yes, I started there. Does not cover 2012+ unique parts and procedures.
