2013 Performance Active Exhaust
#41
#42
#43
#44
just read the post #6
https://www.jaguarforums.com/forum/x...xhaust-192443/
he XKR-S rear muffler has larger diameter pipes coming out of it, larger valves, larger tips which are polished. Internally they are different as well, it's open inside with one of the pipes removed, the other pipes being larger than the standard XKR one.
The 5.0 XK, XKR and XKR-S centre pipes and rear mufflers are all interchangeable, same diameters, same fitment. You can put an XKR-S rear muffler on an XK, the XKR-S centre pipe bolts up to the standard XKR rear muffler, etc
I hope that is true
I hope that is true
#45
If you are after a louder exhaust then you wouldn't need to worry about connect the vacuum pump anyway as the valves are open by default. Just pull fuse 19 in the fuse box behind the rear seat back, if you haven't already.
