2013 XKR - Floor Mat Hook Problem
So its actually a XKR-S...but this part of the car shouuld be the same as a XKR or even a XK. It came with floor mats and when i was taking the driver side mat out to put a all weather mat in i noticed one of the hooks would not come out well - thats because it lifted off and out of its groove like butter!!!! Its still attached (not sure where) but very loose and not solid like the other one. There is nothing to snap back into place so its staying loose. Anyone ever have a loose floor mat hook on their recent XKR? Think the dealer can do something about this without taking the whole carpet out? Going to contact the dealer - who should LAUGH that I am taking the car in for this but if you just paid 6 figures for a car PLUS...you dont want anything not being pristine out of the gate!! What do you guys think? anyone else have this problem? Easy to fix???
Loth
Loth
Firstly, I agree - you pay 6 figures for a car, the car should be without defect nomatter how mall.
In my 2010, in front of drivers seat, the hook nearest the center console came out the first time I took the mat out. Apparently they are sewn in (?) and it was no big deal so I never did anything about it. My mat still hooks onto the other hook and has never moved around so, again, no big deal to me...
But by all means take it in! Let us know how they fix this...may have to get the needle and thread out!
So its actually a XKR-S...but this part of the car shouuld be the same as a XKR or even a XK. It came with floor mats and when i was taking the driver side mat out to put a all weather mat in i noticed one of the hooks would not come out well - thats because it lifted off and out of its groove like butter!!!! Its still attached (not sure where) but very loose and not solid like the other one. There is nothing to snap back into place so its staying loose. Anyone ever have a loose floor mat on their recent XKR? Think the dealer can do something about this without taking the whole carpet out? Going to contact the dealer - who should LAUGH that I am taking the car in for this but if you just paid 6 figures for a car PLUS...you dont want anything not being pristine out of the gate!! What do you guys think? anyone else have this problem? Easy to fix???
Loth
Loth
WOW...that is exactly what mine did!!!! Same one too!! I bet its a manufacter defect and quite a few have them!! The one closest to the door is rock solid without problems - YES. Very first time I took the mat out it came up!. It actually makes me feel better knowing that I am not the only one!
Loth
Mine was actually missing the same clip so after examining the existing clip I found a replacement... a GM floor clip:
It slids in then the bottom piece clips into the top, problem is I have never been able to clip them together since I cant get to the bottom half to press it in as its under the floor.
Dear LORD...I hope an apprentice was NOT installing anything on my 6 figure car!!! COME ON!!! Will this be easy to fix Adrian??? The floor mat hook problem that is...
Apprentices have to learn! They are allowed more time!
I looked at my '07 XK Coupe floor mat hooks and they are plastic and are attached to the carpet not the floor. My guess is they are in two parts; the hook above the carpet and a base under the carpet. Being plastic they must clip together, not sewn.............typical of most plastic parts they go together easily but are difficult to take apart unless they fail (break). Depending on the failure I would expect the carpet needs to be removed unless the hook base can be glued with epoxy.
Glue sounds like the easiest solution but $35! ooch.......try the GM or whatever ones!
Today most brands have hooks (even Toyota's now)
Good Luck, Adrian
Good Luck, Adrian
Given that Jaguar tend to carry over the design principles of fittings from one model to the next, do the mat hooks on the XK look like the earlier XK8?
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-33/25099d1350902772-2013-xkr-floor-mat-hook-problem-carpet-retainer-jpg)
If so, these ones stick to both the floor carpet and the floor panel beneath. When the plastic link between the two parts shears, it allows the main carpet to lift slightly as the mat is removed.
britannia (10-22-2012)
99xk8guy
06-05-2023 06:28 AM
