303 or RaggTopp - which do you use ?
Looking to treat my top for the summer and trying to choose between 303 or RaggTopp. Which have you used and how do they compare in terms of -
Ease of application
Ease of cleanup surrounding paint/glass
End Result of being water repellent
How much UV Protection to fading
Lasts months or a few washes
Does it run and create marks on paint/glass after getting wet
My XK is really only a sunny day weekender and so far only came out in the rain the day I brought her home
Ease of application
I use 303, and while it CAN be messy to apply, I choose to use a lint-free cloth and really saturate it. That way I can control edges and such better. No clean-up.
I don't have streaks anywhere and it leaves a nice color and uniformity.
It does last months on my XKR, but then again I park in a garage. Water beads off six months later, but I reapply every six months regardless.
I've never tried RaggTopp.
ralphwg (06-06-2017)
GBCat,
I too just applied RaggTopp today. Seemed to go on very easily though, yes, I did mask and cover the paint & glass areas. I don't think this car has ever had top treatment and am hoping it will now bead water rather than soaking into the fabric.
At some point a previous owner appears to have (mis) used a power washer on the top and did some cosmetic damage. RaggTopp won't improve the looks but I'm hopeful it will make the top shed water again.
If this product doesn't do the job I'll move on to 303.
Fingers crossed.
Fingers crossed.
Received 2,012 Likes
LoudHogRider (06-06-2017)
Totally agree with kj07xk on 303 and the process of using a brush to apply. I followed richzak's instructions and wasnt disappointed. No need to mask anything. If there is an accidental run, just wipe it off with a dry rag. I just applied 303 this past weekend in preparation for the hot summer days ahead. Also, 303 is recommended by Sunbrella.
My top shop recommended and uses RaggTop. I tried it but water didn't bead on it. A year later, I used 303 and the water still beads 6 months later.
I just sprayed it on after masking everything and it came out fine. I imagine that brushing it on may give a heavier and more even coverage.
The Raggtop versus 303 is going to be subjective answers. I used Raggtop on my previous porsche and it worked well. I have been using 303 on the Jag with success.
I find the brush method much to wasteful of the product. I simply partially open the top and lay an old sheet over the windshield and through the cockpit. With the rear of the top in open position I move the sheet over the rear. This so that I don't get any overspray, plus I can brush in spots that are difficult to cover. I use a random cardboard piece that I make close to size for rear windshield. Because of Amazon I always have plenty of corrugate to pick from. Don't spray outside as any wind messes up the coverage.
Only takes 10 minutes and I get much more usage out of the bottle.
I have a friend that has never treated his top and it looks fine after 10 years. Doesn't leak, has normal fade. Daily driver in Florida with full exposure to elements.
That is what I do, crack the top and just pull an old sheet over the windshield and through cabin. I hold pull it up close to edges when by the sides so spray doesn't get in cabin, your windows will be down with top unlatched.
Do what makes you comfortable, if you try one way and don't like it scrap that method.
myexcursion (06-07-2017)
