does anyone know what 3rd party harnesses match the x150?
i know the volvo one matches the Integrated Audio Module with a different pin out. the other 2 im missing are the information and entertainment control module green 16 pin and the one fore the touchscreen that only has the red and the black wires connected to it which also looks like a 16 pin harness.
IECM IECM IAM Touchscreen Whole Head Unit
mine is a 2012 jaguar xkr convertible with bowers and wilkins which i believe is the upgraded system.
the headunit above with the plugs in is my actual head unit
i believe the part numbers as per the electrical guide is IP087, IP061, IP063
Im working on replacing the stock head unit with a 3rd party one. its a project and i dont know if it will work but i do not want to touch any of the stock wires so im looking for 3rd party harnesses so i can use those wires.
attached is a working project.
slash, that's a good diagram but it leaves open some questions.
Do you have the connector that mates with the male 16-pin connector on the touchscreen that you show in the next to last picture in your original post?
Have you traced the wires you will need to run to the terminating connectors?
Do you have replacement connectors for the ones at the termination of these wires? (You said you did not want to alter the current wiring)
currently i only have the intergrated audio Module Harness. this is the same harness people use for the AUX hack. i do not have any of the other harnesses. im considering buying a full OEM harness and IECM and creating my own harness. i do not have any plans for the Display Screen harness. i am trying to see if Metra has something that fits.
the wires are layed out pretty clear in the electrical guide. so ive traced what i believe to be the right wires that should go to the pioneer harness. i will be testing them before connecting them.
for your last question i will be using a male to female harness retaining any unused. concept below
There are other open questions which i havent addressed in my original diagram
It sounds like you have done a lot of research. I don't think I can advance the solution further than where you've got. Good luck with it and let us know how it turns out.
