4.2 supercharged
There were many changes between the two engines. They did not just slap a S/C on top and call it good. I know the compression ratio was reduced to accommodate the S/C. I believe the rods and pistons were also changed. Search the forum, there are many threads describing the changes you asked about.
The following 3 users liked this post by steve_k_xk:
Either way, good info!
VVT version has NA cams before they had their own profile
MoparDude (04-07-2022)
Powder rods and pistons are able to handle higher horsepower than traditional forged parts and are considered nearly unbreakable.
guy (04-07-2022)
I do recommend he gets the audio aux kit:
https://rimmerbros.com/Item--i-C2P16491
and the Bovee 1000 30 pin device so he can bluetooth music over:
https://www.ecstuning.com/b-tune2air...r/wma1000~t2a/
and a Mongoose/Mangoose Cable so he can use SDD to turn on the Aux port that the physical kit gets him. I will say the Bovee is great in that I don't do anything, I synced it and it just works. I've had more fiddlyness with OEM built in bluetooth in some cars, and have tried like the TuneFly in my Maserati and gave up and ended up getting a Bovee for that and its great there too.
Basically, the cliffs is that the SC is much easier to change the SC oil on (the screw is up front), and the water pump is fine, and the timing bits are fine, and theres no direct injection and its fine. For the most part, the issues he'll have are X150 platform issues, not 4.2L related ones. So like the duck bill and the shrinky dash.
I have the SDD that he'd use since he's an apartment dweller and his mom attempted to raise him after he was kidnapped to a different state than me, so I didn't get a lot of grow-up time with him so he's kind of behind on a lot of 'man' things.
I've also already suggested the BOVEE to him.
. Going off the sheets it appears the S/C and N/A have always shared the inlet camshaft and only run different exhaust cams.
S/C 240° 9mm lift inlet / 220° 8.1mm lift exh (AJ33/34)
N/A 240° 9mm lift inlet / 230° 8.5mm lift exh (AJ33/34)
Please do your research before u call yourself buying a fast car.With that said,you pretty much just answered your own question.
User 070620
05-06-2019 05:22 AM
