4.2 Throttle body VS 5.0 Throttle Body
Right so you bored the elbow going from throttle to inlet manifold to suit the larger throttle.
Also what size is the opening on the inlet manifold and did that require match porting as well ?
Will be good to see the amount of airflow you have compared to mine with these mods
Priv have you got a scanner that reads g/s at your MAF to compare , my readings were the following-
Standard 75/76mm throttle body 258g/s @7400
Maxbore 81mm throttle body 252g/s @7400
Was thinking with the increased rpm the larger throttle would add more power, but across the entire rpm range it was down.
#28
#30
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
#32
Well last time he stopped by to get a tune , I refused to work on his car due to aftermarket intake with Chinese MAFs., That was 1.5 yrs or so ago..
__________________
guy (12-08-2022)
