4.2L XKR Exhaust Options
I have removed the Fuse 19 on the exhaust, and I love the way it sounds in general. However, one thing that is not consistent is the amount of "popping" and crackling that I get on aggressive decelerating downshifts. It seems to depend a lot on weather conditions (I get more of that sound when the car is cold and the weather is cold, too).
I am usually staunchly opposed to modifying the car, but I really think a minor tweak could really increase my enjoyment of the car! So what are my options? Has anyone had any luck with getting the crackling/popping sounds on the 4.2 XKR? I would like to keep the exterior look completely stock.
I would love the sound like what's here at 0:30 or so...
Consider trading in your current Jaguar to buy the F-Type or XKR-S...then you get the sounds from the exhaust that you want without any mods.
OR
Take your Jag to a performance exhaust and muffler shop and let them install a whole new system. This is the easiest. Pulling Fuse #19 cannot duplicate a custom built exhaust system for your car. There are plenty of performance shops that can assist you. They are everywhere.
OR
Maybe I'm being dense. Does doing this mod remove the catalytic converters? I thought it just deleted the resonators.
If I had to do it all over. I would do this mod. Fairly cheap and great result..
Remove resonater 14 and 15, with straight pipes, leave the back box, and remove fuse 19... Then you are good to go..
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/74198-4-2l-xkr-exhaust-options-exhaust_component_location2_zps8e67d780.jpg?dateline=1393519964)
Not too intrusive, and still great burbel and deep sound, much improved over the stock version...
My 2 cents..
good luck..
or have a look at this thread..
https://www.jaguarforums.com/forum/x...estion-103561/
My 2 cents..
guy (04-22-2015)
Thanks. I was reading that other thread. Then I came across this Corvette thread.
http://m.corvetteforum.com/c6-corvet...ml?styleid=140
People on that forum say going to a crossover pipe definitely reduces the amount of popping in the exhaust, which is exactly the opposite of what I'm wanting to do. So maybe the solution you suggested would help me achieve what I want--just remove the two resonators!
Has anyone actually done this? And what does it sound like?
ndy.boyd (02-27-2014)
If you are receiving too much interference with background noise, try a cheap and simple gadget to help concentrate and collect the sound. Check out these photos, very simple devices you could make that may help.
While these people appear to be using them to amplify their speakers, the idea should work similarly well for collecting sound. ...similar to cupping your ear.
idk, worth a shot maybe...
jahummer (03-03-2014)
amcdonal86 (03-03-2014)
A couple of months ago I was at a Jag service department and a client was having his XKR exhaust upgraded to the factory performance package and it looked no different than what I did.
M6XKR (03-06-2014)
