4.2L XKR Exhaust Options
If I had to do it all over. I would do this mod. Fairly cheap and great result..
Remove resonater 14 and 15, with straight pipes, leave the back box, and remove fuse 19... Then you are good to go..
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/74198-4-2l-xkr-exhaust-options-exhaust_component_location2_zps8e67d780.jpg?dateline=1393519964)
Not too intrusive, and still great burbel and deep sound, much improved over the stock version...
My 2 cents..
good luck..
or have a look at this thread..
https://www.jaguarforums.com/forum/x...estion-103561/
My 2 cents..
![](http://imagizer.imageshack.us/v2/1024x768q90/850/u659.jpg)
That's the Spires "stage 1" exhaust, from Spires Performance here in the UK. I know they do ship to the US so give them a call. The pipe above basically removes those center silencers and adds a crossover pipe.
This was how the car sounded with standard exhaust, minus fuse 19:
And this is it now:
So a rounder, fuller, more throaty sort of sound and maybe about 15% louder across the board, although that's a bit hard to tell from the videos. Well worth it IMHO and I personally wouldn't really want it any louder.
The following 2 users liked this post by 8bit:
sherbercars (03-04-2014),
Stormdk (03-04-2014)
By the way the H pipe is less efficient, hence the X.
amcdonal86 (03-04-2014)
The following 2 users liked this post by u102768:
amcdonal86 (03-04-2014),
Ngarara (03-05-2014)
#30
#31
This is more or less what I've done. Fuse 19 is out, and I had this fitted in place of the mid section:
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/74907-4-2l-xkr-exhaust-options-u659.jpg?dateline=1393986636)
That's the Spires "stage 1" exhaust, from Spires Performance here in the UK. I know they do ship to the US so give them a call. The pipe above basically removes those center silencers and adds a crossover pipe. This was how the car sounded with standard exhaust, minus fuse 19:
Jaguar XKR - Standard exhaust - YouTube
And this is it now:
Jaguar XKR - Spires stage 1 exhaust - YouTube
And this is it now:
#32
#33
jagtoes (03-05-2014)
#34
I haven't opened the muffler, but there's a diagram in the 4.2 workshop manual (strangely missing from the 5.0 manual) that shows the exhaust flow as separate:
Attachment 74922
Attachment 74922
My understanding is that they're not; I gather they're just straight pipes with a couple of boxes full of glass fibre welded on to them so the crossover in the XKR-S and XKR75 Performance Active exhaust is a new thing.
Edit to add - yes it is stainless steel.
sherbercars (03-05-2014)
#36
I think he meant that the small silencers in the middle section are internally open, a bit like crossover pipes.
I think I paid around GBP 500 for the pipes plus shipping to me in Scotland, overseas would I guess be more. I had a go at fitting it myself on my driveway with the car on axle stands but ended up getting a garage to do it, took the guy a couple of hours.
#37
#38
#39
OK. Ive just spent the last hr. learning about Crossover and H type, And now understand it more , Im old school dealing with lower reving engines , what I have found out is that the Crossover is better at higher revs as far as power goes . but according to what I read it is quieter and no popping. On the other hand the H type is better at the lower revs but not as good at the higher end for power , but has a deeper sound and more crackle & pop, Myself Im more for the sound not the power, I find the XKR has all the power I need , but I would like it to sound more aggressive, My 40 Caddy sounds like it has all the power in the world with its 500 hp ,but is nowhere near as fast as my Jag. but sounds better.
I did find the crossover on Jeggs web page it is around $100. or less.
I thank you all for this post . You learn something every day. Bernie
#40
sherbercars (03-06-2014)
