5.0 oil change question?
Old 12-02-2013, 07:41 AM
chazaroo's Avatar
Default 5.0 oil change question?
The manual on my 2010 XK calls for Castrol and the dealership told me it's a special Castrol blend for Jaguar and you have to use it. Anybody know why?
Old 12-02-2013, 08:59 AM
Received 2,263 Likes on 1,845 Posts
The manual calls for a particular specification of oil and of course viscosity. Use whatever brand meets both requirements.
Old 12-02-2013, 09:09 AM
bocatrip's Avatar
I believe it's 5W/20. I plan on using Mobile 1 as I have used in every car I've owned. I hope Jaguar doesn't make a stink about it with regards to the warranty.
Old 12-02-2013, 09:38 AM
Here's what the manual says:
"Use only 5W-20 engine oil, meeting
specification WSS M2C925-A."
The following 4 users liked this post by Mikey:
bobdr1 (12-06-2013), chazaroo (12-02-2013), drphilgood (03-11-2024), JonWat (02-22-2016)
Old 12-02-2013, 10:31 AM
My dealer's service dept told me it was just castrol, re-branded for jaguar.
Old 12-02-2013, 10:34 AM
chazaroo's Avatar
here is a extract from the Jaguar training newsletter regarding Castrol. Looks like using anything else could be a warranty problem. Brilliant cash hustle by Jaguar.:
· Stable viscosity for sustainable performance
· Improved engine cleanliness and engine protection
· Better ability to compensate for various driving styles
There are several features your new Jaguar customers should know about:
· The new Castrol oil, SLX Professional 5W-20, is the only oil recommended for the new 5.0L AJ V8 engines
· A service reminder in the Message Center lets the driver know when it's time to change oil
· Service Interval is every 15,000 miles or 12 months, whichever occurs first. It's important that your customers visit your Jaguar dealership yearly for annual service
· The first scheduled maintenance service visit is Complimentary
· Maintenance Interval Message automatically appears when it's time for service
· Checking the oil level is simple using the built-in "digital dipstick" on the car's onboard computer. The new engine does not have a traditional dipstick
The Jaguar/Castrol co-engineered 5.0L engine 5W-20 synthetic motor oil is the only lubricant completely tested to be compatible with Jaguar’s new engine components and other fluids and sealants. No substitutions should be made as the warranty coverage requires the use of the proper Jaguar specified lubricant.
Old 12-02-2013, 11:44 AM
R_Rated's Avatar
Yes - use this grade in your preferred brand. There are a couple of boutique brands out there that offer high heat protection also.
Old 12-02-2013, 12:16 PM
The devil is in the detail. There's a difference between 'specified' and 'recommended'.
Jaguar 'specifies' lubricant that meet WSS M2C925-A and they 'recommend' Castrol brand. You're free to choose whatever brand that meets the spec.
Yes, it's slimy doubletalk.
The following 5 users liked this post by Mikey:
bobdr1 (12-06-2013), chazaroo (12-03-2013), drphilgood (03-11-2024), gctippett (05-07-2022), Stuart S (05-11-2016)
Old 12-02-2013, 12:50 PM
TheMCP's Avatar
I used Mobil 1 Extended Performance oil when I did mine... it meets the specification listed in the manual. Finding an oil that met that specific spec was more difficult than I would have thought...
Synthetic Oil | Mobil 1™ Extended Performance
Old 12-03-2013, 05:24 AM
bobdr1's Avatar
Good question about the warranty issue. I just purchased a 2010 xk coupe, 25000 mi. Certified 6/100000mi I have a 3 hr round trip to nearest jag dealer and they want $300 to change oil. I have a reliable local shop in town that works on my out of warranty 2009 xk convert. Would prefer to just have it changed locally with proper oil of course but dont want to get in a stink with Jaguar dealer if future problems arise under warranty. Any problems with changing oil locally? thanks
Old 12-03-2013, 06:13 AM
chazaroo's Avatar
FYI, I just had an oil change done on my 2010 at the dealer. Cost was $210. Your dealer's price is out of line.
gctippett (05-09-2022)
Old 12-03-2013, 09:55 AM
Lothar52's Avatar
There is a shop in NE Ohio that is Jaguar Certified independent shop - 70 dollars for an oil change.
Old 12-03-2013, 11:40 AM
chazaroo's Avatar
For a 5.0? I found prices like that for my '07 but the new 5.0s are considerably more.
Old 02-18-2014, 04:18 PM
bobdr1's Avatar
Jaguar service rep recently informed me that Castrol Edge synthetic 5-20W oil which is readily available is what is recommended for 5.0 xk. No longer is it specific castrol oil only for jaguars.
Old 02-18-2014, 04:29 PM
bocatrip's Avatar
My local Jag dealership charges $150. It does take a lot of oil. Considering I'm planning on taking out a 5 or 6 year extended warranty (Easy Care/Total Care) I don't want any more loop holes available to Jaguar for any future issues. I don't drive much, and one oil change a year will not break me. I'll let them make some money on the oil changes. Is the Castrol oil used by Jaguar definitely a fully synthetic oil?
Old 02-18-2014, 08:56 PM
mgaffney's Avatar
If all you had done was an oil change then your dealer's price is also way out of line. It's just not that hard to do...
Old 02-18-2014, 10:25 PM
richzak's Avatar
Received 1,235 Likes on 789 Posts
My quote for an independent to change the oil, filter, check all fluid levels was $90.00 while the dealership (Jaguar) located in El Paso, Texas charged me $120.00 for the oil, filter, full car inspection and replacement of a two light bulbs in the trunk.
If your using Alpine Jaguar located in Ft. Lauderdale, I can see why they charge so much. Alpine is a prestigous Jaguar dealer. When I was in their dealership last month on a visit to Pompono Beach the dealership is very upscale. It was like entering a top notch Wall Street brokerage, taking the elevator to the second floor, being greeted by some hot babes then walking through their glass window second story showrooms. Top of the line for being a classy dealership, so I could see why they charge so much. However you could be dealing with West Palm Beach Jaguar also. At Alpine, I think their customers are paying for the geographical area that the dealership was in. Their is a ton of wealth in that specific area.
I was most impressed with the Ferrari/Maserati dealership located on Federal Hwy in Ft. Lauderdale. Wow, what a showroom of beautiful bright red Ferrari's.
However, I am with you, I will let the Jaguar dealership do it for the $120
Old 02-20-2014, 01:11 PM
axr6's Avatar
Does anyone knows where the oil filter is located for the 5.0 XKR and what it takes to change it? I will want to change oil and filter when I receive my car and prefer to do the changes myself.
I changed oil in all my cars, including the two previous 4.2 XKs. Looks from a parts diagram that the 5.0 engine uses a cartridge type filter but, can not find a drawing with its location.
Old 02-20-2014, 01:21 PM
Executive's Avatar
Albert, if it's in the same location as the XF then. i think it's near the left bank towards the top. Should be right under the engine cover. Have you tried lifting it off?
See the round black plastic piece, north of the intake tube? That's it.
axr6 (02-20-2014)
Old 02-20-2014, 01:33 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Take off the plastic engine cover and you'll see the casing immediately - it's just in front and to the right of the supercharger. Leave it for at least 2 minutes if the car has been running, to allow the oil to drain out of it. The casing unscrews (4 turns), bringing the filter element with it, then the filter element can be pulled out and the new one pushed in. Replace the large O-ring on the casing. Make sure you oil the 2 O-rings on the filter element before you screw it in to finger tightness. It should be torqued to 25 Nm.
Quick Reply: 5.0 oil change question?
