5.0 XK Low temperature thermostat install
Good day everyone,
This past weekend I fitted a low temperature thermostat rated to open at 85c vs the 95c stock one.
After testing the thermostat successfully prior to install, I installed it and a new thermostat housing.
A few observations were made:
My original thermostat only has one resistant spring inside the housing.
The new thermostat has 2 springs inside the housing.
The original thermostat's spring is easy to compress
The new thermostat has a very stiff spring.
Results:
Car actually runs hotter than it used to staying steady around 95-98c highway and in traffic
but very consistent.
I understand the ECM must be repogrammed to kick fans on early to get better cooling from a low
temp thermostat however, on the highway I would expect my car to run cooler, not hotter.
I am considering putting in the stock 95c thermostat back in.
Thoughts?
Results:
Thoughts?
