5.0L fuel pump replacement
Got a sudden Restricted Performance on a drive today (2012 5.0L XK). Throws a P0087 low fuel pressure code. I was able to test the low pressure pump and it's pressure seemed fine plus performance characteristics points to the high pressure side.
I've not eliminated the possibility that it may still be a 'bad gas' issue, since I had just filled up for the drive, as well as any other possibilities though. I threw in a bottle of "heet" in hopes that might be of service but am not holding my breath.
Available dealer service are currently closed for the day so was wondering if there might be a member who might have an idea on what cost should be expected if either/both high pressure fuel pumps need to be replaced?
Alternatively, perhaps some insight on DIY replacement.
Its not a good feeling when our baby is sick.
Thanks for the response Mufc. I was able to get it into dealer service today for their diagnosis and found it is in fact the HP pumps. Their quoted cost came to $2600 though.
I'm at a disadvantage in that my location is so remote it is hours away from a dealership and no indie shops that can be trusted. So parts are on order and with lock will have it back early next week.
Its got about 68K on the clock with no symptoms other than the sudden DTC. I'm pretty sure SDD was how they ID'd the failed pumps. I caught a LR training Youtube video on the 5.0L DI that described the high pressure pumps as a significantly weak point on the engine. I don't know if others with 5.0 on the forum have had the same issue though. Cursory searches didn't indicate that but I didn't look in great detail.
I don't max out fueling on the XK.
I'm still dealing with my sick cat - 2013 XKR (25K miles). My restricted performance mode happened during a moderate acceleration. Lost a 1/4 tank of fuel on an 8 mile drive home. Absolute pressure problems and the unfortunate problem of fuel flooding my cat convertors and likely a mess of gas in my oil. Like you, no local Jag dealerships so I have located the mechanic that used to work for Terry's Jaguar. He's dropping the exhaust and aerating that, draining the oil to investigate for fuel, and pushing out any leftover gas in the cylinders. We still don't know what is going on for sure but it appears like HP on one side is freaking out, opening all fuel injectors and flooding it with fuel. ARGHHH!! I'll be happy with $2000 or less on this repair. And it may end up 2 hours away at the closest Jag dealer if he can't get this taken car of. Good luck on yours!
Okay, now wait a minute............... This seems similar to a Faulty Injector and not a pump. Besides, high pressure pumps rarely go bad.
If one injector goes bad, they usually go bad in the OPEN state, and therefore dump raw fuel down the one cylinder they service. Result: misfire on that cylinder because BooKoo (beaucoup) FUEL.
All the fuel from that High Pressure Rail goes into that one Open Injector, results in the OTHER three injectors Starved for Fuel. Result: misfire on all cylinders, HP pump code.
Although your initial description of your original problem seems a bit off for the normal complaint of Bad Fuel Injector, it could still be construed as such...... Limp Mode, Lots of Gas Smell, Fuel in Oil and Fuel out the Tailpipes.
You may want to double check on this before you commit to replacing a HPFP.
Strange...all these posts and no codes pulled?
Plug a basic OBD2 scanner in and pull all the codes your car is throwing.
Diagnose each code. Codes can be contradictory sometimes until you see them all together.
I imagine there is a code book stashed in this forum.
Seems like the Jaguars don’t pop CEL until something terminal happens.
Edit - My bad, there was a code in the OP. Strange that was the only code though. I thought the codes would specify more specifics.
Sometimes it can be something basic that causes these things.
Although it was cool having flame out of the exhaust.
Not having codes to troubleshoot, it sounds more like Cee Jay may be closer to defining the actual problem than suspect HPFP. Mine was pretty clear from the P0087 code that it was low fuel pressure. Those pumps are on the expensive side to replace so, if it were me, I'd opt to check out injectors on both banks before committing to a dealer shop expense.
Your correct though that you'd still need to have the cats checked and fresh oil anyway.
From reading some of Cee Jay's and others threads it sounds like injectors might even be DIY possible for you.
Received 2,626 Likes
One indication of stuck injector(s) is smoke from the exhaust and loss of power. Quite often DTCs appear for misfires from Bank2 cylinders since there is a differential in fuel pressure between Bank1 and Bank2 due to the fuel lines.
Monitor high pressure fuel system with the Torque app connected to the vehicle PCM via the OBD port with a Bluetooth interface. Fuel pressure should be around 8 Bar.
Got the cat back today! Quite a difference in characteristics though I'm attributing most of that to the hard reset that took place in the repair process. (shifts are now spot on again though it no longer struggles under load)
This is write-up: Technician verified concern. Scanned for codes and found low fuel rail pressure codes. Used data logger and found fuel rail pressure 63psi out of 400-500psi. Replaced both hp fuel pumps, cleared pcm adaptions (probable improved shift performance now) and codes. Test drove, viewed data logger and found fuel rail pressure at 435psi. Repairs verified.
The technician confirmed these are a weak point on the 5.0L and that because both HPFP feed both banks of the engine one had probably failed some time ago before and gone unnoticed. He said they replace both because a) it is almost impossible to bench test pumps, and b) the P0087 codes is not really evident until both are failing.
In addition to replacing both HPFP they replaced the HP fuel lines and changed the oil. He indicated the pumps seals fail internally so the possibility of oil contamination is too great, thus the oil change. Since it had been changed within 500 miles they did not need to change the filter.
The total cost came to $2,791 with tax included. (BTW, it got a complimentary wash too. lol)
I don't know if this of any interest to others but if it is I'm sure it would apply to all JLR 5.0L (at least of the vintage of MY12)
Also: I noticed the "sewing machine" sound with the hood open is significantly reduced now as well.
Gave it some thought, then determined I've got too many irons in the fire to add that too. lol
Yeah, the SM indicated they see them from time to time with both Jag & LR. I didn't investigate if there had been any design improvements to hep negate the problem on later models.
It would be great if no one else here would have to go through it but one can only hope.
Maybe this added detail will help close the thread.
ralphwg (10-22-2020)
Cello5887
06-22-2019 11:57 AM
car5car
02-13-2016 07:00 PM
