5.0SC water pump
Received 2,195 Likes
AJ813909 is the correct OEM, I just sold a new I had on ebay for $130. you need the updated Y pipe , bleed pipe, o ring and stub pipe water pump to oil cooler as well. You may want to just consider replacing the front outlet pipe under the SC as these rupture and you'll be halfway there. And no I do not have the part numbers for all the rest you need.
needs the heater manifold too
