5 months and stuck on the side of the road already
Old 05-30-2014, 01:15 AM
bklynchris's Avatar
Originally Posted by bocatrip
BklynChris. How many miles on your XKR? Let us know how you make out.
47k now
Old 05-30-2014, 06:13 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
I'd be all over Jaguar on this pushing for a replacement car if this is under their warranty. Am high and settle for something reasonable. Who knows what is next on that car? What else got damaged?
bklynchris (05-30-2014)
Old 05-30-2014, 07:29 AM
MaximA's Avatar
Originally Posted by SoCal Babe
Twitchy?? Why be so complimentary? I lowered my car 35 mm and spaced it out 15mm
I was flying at 130 and hit a slight imperfection in the road that wasnt even a bump
I got unbelievable rear end hop. The car is great to look at and drive at reasonable speeds. However it aint designed to run like a scalded dog.
I don't have rattles either, but a loose rear end is worse than saggy *****!!
Try the F-Type damper for the rear as they have better rebound control, or just move to coil overs like I did. The stock rear suspension lowered is horrible and near dangerous over 100MPH. I have to agree for a 500+ HP car they sure left a lot out information as far as gauges. My car is still tight and hasn't had any major issue(knock on wood) but its also not a Porsche GT3 but I was after a comfortable fast GT car, and the choices for me were Bentley Continental Speed GT, or a Ferrari 599, XKR... The other two are maintenance nightmares and a hell of a lot more expensive
I'm using the Kiwi2 wifi with my iPhone for OBDII data. It also records and plays back data which is great for the track.
The following 2 users liked this post by MaximA:
axr6 (05-30-2014), SoCal Babe (05-30-2014)
Old 05-30-2014, 07:50 AM
Fastlane'scat's Avatar
Decking the heads means they put them on a machine that makes the head seating area flat again, sort of like a belt sander. Now if the heads are really bad then junked. Resurfacing is just making the head surface correct for gasket mating.
The following 2 users liked this post by Fastlane'scat:
bklynchris (05-30-2014), Lothar52 (05-30-2014)
Old 05-30-2014, 07:55 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
I see the F-Type has a gauge set on the info screen with at least water temperature. Makes you wonder why they didn't include one fro the XK.
The following 2 users liked this post by jagtoes:
Old 05-30-2014, 08:24 AM
Lothar52's Avatar
This is a call to action. We need to know what exactly is going wrong with these water pumps and they need to be replaced properly with better mechanical equipment.
Old 05-30-2014, 09:32 AM
Lothar52's Avatar
Is it that the mechanical pump is failing or is the hose disconnecting or getting a whole in it? What is the exact problem?? Is this a model specific problem??? Is there a JTB for this problem???? .....I think I have heard of alot of hose problems in 2010...I thought one was a water occurring in the passenger side footwell.
  #28
Old 05-30-2014, 09:36 AM
bocatrip's Avatar
My concern with the failing water pumps is that the replacement has not been updated.
Old 05-30-2014, 09:54 AM
axr6's Avatar
Exactly. That is what I seem to remember being stated by PLUMS here.
  #30
Old 05-30-2014, 10:04 AM
axr6's Avatar
I dont have rattles either, but a loose rear end is worse than saggy *****!!
This is exactly why I do not want to drop more than 3/4 to maybe 1" at the rear, or none at all. I would speculate that with the H&R springs dropping close to 2" you basically reduced your damper travel to next to nothing. If you hit a road imperfection at 130 MPH, you bottom the dampers and your effective spring rates go through the roof to infinity, making the car bounce wildly, nearly impossible to control. You'd be much better off doing 130 MPH with your stock XKR suspension!
  #31
Old 05-30-2014, 10:22 AM
powerhouse's Avatar
Default collant level
how much collant if any will engine use up. what i mean is will it go down a bit with normal use, and need toping up or does it stay the same level not using any.
  #32
Old 05-30-2014, 01:55 PM
bklynchris's Avatar
That's a good idea. I am going to write a letter to Jaguar explaining what happened and the backlash thereof. If I do ask for a replacement car, I wouldn't settle for anything less than what I already have. I would also demand that its a select edition as well. I would be going if this car wasn't under warranty.
  #33
Old 05-30-2014, 02:01 PM
bklynchris's Avatar
I agree. If there is a known issue, then why doesn't Jaguar address it rather than being reactive. After reading the posts here, I'm going to be skittish about the car now. This was easily preventable, especially since they sold the car as a select edition. I'm going to send Jaguar a nice letter and mention this forum in it....to get things started.
  #34
Old 05-30-2014, 02:05 PM
bklynchris's Avatar
So we are to drive our car, knowing that at some point the water pump is going to fail, then contend with the damage afterwards? That doesn't seem feasible, logical or even customer service friendly.These are supposedly high end cars.....I wouldn't call that high end service. I really doubt if BMW or MB would operate like that.
  #35
Old 05-30-2014, 02:14 PM
Bruce M.'s Avatar
The standard H&R kit drops the car 1.3 inches, max. From what my shop has measured, I got maybe 1.25 up front and 1.2 in the back. Not 2 inches, anywhere.
And I haven't taken the car to 130 and gone over bumps of any size. On public roads or tracks.
  #36
Old 05-30-2014, 03:33 PM
bocatrip's Avatar
What is so disheartening, is not if the water pump will be failing but when. To make matters worse..... no warning and then Surprise! Not acceptable.
This is more than an inconvenience not to mention somewhat stressful waiting for the "event"... and it affects the integrity of the most expensive part of the car...the engine!
  #37
Old 05-30-2014, 03:39 PM
bklynchris's Avatar
Would it be best to request new heads? I'm not sure how that works.
  #38
Old 05-30-2014, 03:42 PM
bklynchris's Avatar
Agreed!!!
  #39
Old 05-30-2014, 03:45 PM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
Is it that the mechanical pump is failing or is the hose disconnecting or getting a hole in it? What is the exact problem??
That is what I would like to know for sure also.
I am not sure if it is still the case with the 5.0, but 4.0 and 4.2 V8s had the coolant sensor located near the top of the engine. If you had a major loss of coolant, such as from a burst hose or a hose popping off, the sensor would no longer be immersed in coolant and there would be NO overheat warning! Your only warning would be a low coolant message.
This is why it is critically important on these cars to pull over and see just HOW LOW your coolant really is immediately as soon as it is safe to stop when you get a low coolant warning. If there is no coolant at all in the overflow tank, immediately shut off the engine.
  #40
Old 05-30-2014, 04:04 PM
axr6's Avatar
Chris
My advice would be to just let Jaguar take care of the car under warranty without making any "demands". They will probably play nice and fix it for you fine. If you were to stick to "demands" and hold out for new this or that, they may pull the history files from your car and point out that you drove 40 - 50 miles with on-off low coolant warnings, which could effect the warranty coverage.
Better fly low, IMO.
The following 3 users liked this post by axr6:
bklynchris (05-30-2014), ralphwg (05-31-2014), SoCal Babe (05-30-2014)
Quick Reply: 5 months and stuck on the side of the road already
