ABS bleeding?
ABS bleeding?
My brakes feel a little spongy on initial application. If I release then immediately reapply the brakes it does feel firmer and more positive but after releasing the pedal again for a while the next time it's gone spongy again. I've bled all the calipers but it still feels a bit vague on initial pressing of the pedal. For context, my wife's 2014 XF S has far better and more consistent braking feel than my car.
I plugged in my SDD laptop last night and found a routine under Service Functions called "Brake Bleed" but there's zero explanation of what that involves or attempts to achieve. My iCarSoft device also has a Brake Bleed function within the ABS service functions. I've never had to bleed the ABS system on a car before so no idea what's involved, has anyone ever done this and can explain please? Alternatively, anyone else had the same sort of symptom and able to share their resolution?
Thanks for that, I did see that in the workshop manual but haven't had a chance to try it. Ruled D1 and D4 out already though but might be interesting to try the other tests. I just plugged SDD in last night to see if there was anything potentially useful when selecting the symptoms of the brake pedal and saw the things I mentioned in my OP.
Had a similar issue, so I decided to bleed my brakes. I could see all the air bubbles coming out the whole time. Just kept coming and coming out lol.
Still felt like there was air in there, so I decided to have the dealer bleed them for $200. Well worth it. They seemed to get all the air out and the fluid in the reservoir still looks cleaner than ever.
And much firmer pedal now too.
As you are in Scotland you may like a UK widely available and low cost option for bleeding.
I use a Gunson Eezibleed kit with the addition of a non-return valve for the caliper tube end. It's the most basic, cheapest and easiest solution for pressure bleeding without needing an assistant to close the bleed screws. Very effective and makes a bleed or fluid flush a straightforward job. I bleed ABS with the engine running.
Plenty of more expensive pressure or vacuum equipment available if you prefer a larger volume supply reservoir or independent air pressure.
When bleeding, make certain you start with the caliper furthest from the reservoir and bleed at least a good pint (or more if needed) from all 4 calipers, sometimes just a little bleed accomplishes nothing. The routine does work on our cars but there's no need for it in your application.
When fitting a new ABS unit, first the brake system is filled and bled via traditional methods which bypasses the ABS module, then the routine is run via SDD and the brake system is bled again one caliper at a time. The routine allows fluid to run through the ABS to remove air in the new ABS.
Richard
8bit (03-30-2022)
Thanks gents. I haven't fitted a new ABS unit, I did replace the rear calipers recently but this poor pedal feel was present before that. I obviously bled the rears and the fronts as well (car was due a brake fluid change anyway) so was hoping that would cure it but I guess there's maybe a little air in there somewhere. Found the part number for the ABS pump and searched Google, found a listing here - https://www.ebay.com/itm/Anti-Lock-A...1831972?_ul=IL
Don't see anything on there that looks like a bleed point unless anyone knows better?
The "traditional" method of flushing the ABS pump is to change the fluid in the regular system and then go out and stamp hard on the brakes a few times to activate the system.
Richard
8bit (03-30-2022)
