ABS fault
ABS fault
Hi there. These codes keep coming back then disappear for a little bit and then come back again.(battery is tricked charged every week) The ABS fault on the dash comes on usually every time I start it then on the way back it usually dissapears. All the sensors are working. Last night the handbrake kept releasing it self also. Some help would be greatly appreciated.U0415U0401
Received 1,177 Likes
Yes. there are so many threads on this very issue.
You may keep the battery charged but the million dollar question is: what is its current capacity?
I think you will find that if you disconnect it for 12 hours following you “fully charged” state, it will not register well.
Invalid data, Abs issues and epb issues have one common root cause… there is a reason why in the workshop manual it clearly states “confirm battery is fully charged”, first.
ralphwg (03-19-2024)
guy (03-21-2024)
Mclovin22
10-12-2023 08:11 PM
JaguarXJR02
05-19-2013 06:55 PM
03JagSType3.0
09-25-2012 08:32 PM
frombenz2jag
01-16-2008 05:38 PM
