AC Leak from Evaporator
Hi guys,
Has anyone attempted to change the evaporator on a 4.2 N/A Coupe.? is it possible to remove or access the evaporator from the footwell or does the dashboard have to be removed to gain access?
I'm not looking forward to doing this one. Any help with the order of procedure would be greatly appreciated
Yes it all has to come apart. Did you check pricing on a new evaporator? How much of a leak is it? I had mine diagnosed a year and a half ago with a pinhole leak. Takes about a year before you start to notice it so instead of all of the work and cost to do that (they wanted over $3k for the repair), I just top it off with a $40 bottle of refrigerant. Works great if you can get away with it.
R14a Refrigerant at Walmart for $4.88
That’s just for a small 12oz refill can. The kits range in price from about $30 all the way to $60. I used the $60 one in order to get the reusable digital refill gauge too, had a 25% off coupon plus $20 mail in rebate so my final cost was really only about $25. and it took more than half the 22oz can it came with. Next time I need to fill again, I can buy the less expensive refill.
https://shop.advanceautoparts.com/p/...7CL4*-49996539
Cee Jay (10-05-2020)
Thanks for the quick reply, I was hoping you were not going to say that.
I had the AC charged up this summer as the system was empty. I also had a can of the STP leak seal added at the same time,unfortunately It didn't seal and it only lasted a week. I returned the car back for further diagnoses and the chap re pressurised the system and used one of those sniffer probes to locate the leak. When he directed it over the left hand cabin vent and the sounder went berserk.
I've managed to source a S/H evaporator which I will have tested before I fit it.
Again if anyone has a schematic of the dash bolt positions and a rough order of removal would be helpful
I've had hoses and pressure gauges for years Years hell, I got them in 1991 and they still work perfect. I had to buy a new can-side hose when the can styles changed to Reusable, but that cost me a whopping $7. A reusable hose with a gauge is like $15 and you can use it on any R134 can from anywhere.
I've used my small setup to charge friends and neighbor's vehicles for years, and I'm sure they all liked paying $5 for a top-off than however much a shop would charge ($89+???. Also way less than your single-use 22 ounce.
Course, if you only NEED 22 ounces and don't already HAVE a hose, then your deal would work just fine.
Reusable R134a hose with gauge from Amazon
Unfortunately none of this helps the OP as his leak is more severe...I wonder if we shall see more of these leaks as they age?
Received 1,975 Likes
There was a member that did a removal and wrote some pretty good info with pictures. It’s in a thread here... somewhere...
Thanks again
