Switched, unswitched 12V power and ground are conveniently available in the "boot" or "trunk" of our XKs and XKRs immediately adjacent to the left tail light.
Typically a white or black plastic plug secured adjacent to a sensor bracket, it is unused and awaits your creative application (back-up camera, etc).
Brown wire: unswitched 12V protected by F10 (10A). Fuse in the RSJB
White w/Red wire: switched 12V protected by F23 (10A). Fuse in the FSJB
Black: Ground, secured to the body nearby
Fuse values and numbers are as noted for 2010/11 models but should be typical for all XK/Rs. CA052 Socket Accessory Rear
CA052 Accessory Socket Rear - Black
Reason: add photo
GGG (09-01-2022),gkubrak (08-30-2022),gmuirnz (11-16-2022),ralphwg (09-03-2022),sailfish (08-31-2022),Sean W (09-01-2022),V7Sport (09-01-2022),WVChris (08-31-2022) and 3 others liked this post. (Show less...)
Switched, unswitched 12V power and ground are conveniently available in the "boot" or "trunk" of our XKs and XKRs immediately adjacent to the left tail light. .....
Added to XK/XKR - 'How To' / DIY Repair & Maintenance sticky under section 4. ELECTRICAL with acknowledgement.
