Accessory drive belts and tensioners removal - DIY?
Has anyone tried changing accessory belts components (engine and SC belts, idlers, tensioners) by themselves? Did you have to remove hood and front bumper? Manual only mentions radiator splash shield and air deflector removal, but I don't see how can you reach all of the components with all that in the way.
Received 1,123 Likes
Cee Jay (12-17-2020)
The following 4 users liked this post by GGG:
That will definitely help. However, regarding tensioners specifically drive belt tensioner, manual states that you even have to raise the engine, so I guess I'll skip them heh
Lord_Eduard (12-18-2020)
Ok, so to summarize, if I'm to change accessory drive and SC belt and it's idlers/tensioners, I have to put bonnet in vertical position by detaching struts and use 1/2" and 3/8" torque wrench? Everything else stays in place? If this is so, I'm definitely doing this alone, saving myself lot of time (lasy mechanics) and money.
Also, I have ordered from Powehouse 6% SC upper pulley so I'll install it as well. As I understand, there is special tool just for that and it makes this op much easier. But I guess there are other ways to remove pulley from SC snout..
Received 2,646 Likes
Lord_Eduard, I did all that as part of my valley pipe replacement weekend. Including water pump. No need to remove anything like you ask, and no need to have hood vertical, I didn't know it was possible. What I found critical due to lack of space up front, was sequence. Here's part of my earlier thread on this:
Water pump, belts, two tensioners and two followers. I found a certain sequence is necessary, there may be others, but this works:
-SC tensioner moved, SC belt taken off tensioner
-SC tensioner taken off, laid to the side, can't get it up at this time
-SC belt can now be removed
-ACC belt tensioner moved, ACC belt taken off tensioner
-both followers removed
-coolant pump off
-loosen ACC tensioner, ACC belt removed
-triangular bracket for SC follower (3 bolts) removed
-now SC tensioner can come up, new SC tensioner down
-ACC tensioner removed
Reverse is from the bottom and up.
And here are the pages you find help in the manual:
-coolant pump off
- Supercharger (18.50.15) 1823
- Coolant Manifold - Vehicles With: Supercharger 1603
- Cooling System Draining, Filling and Bleeding - 4.2L SC V8 - AJV8 1516
- Supercharger Belt (18.50.08 ) 1701
- Radiator Splash Shield (76.22.90) 3126
- Throttle Body Elbow (19.70.28 ) 1829
- Exhaust Gas Recirculation (EGR) Valve (17.45.01) 1755
- Throttle Body (19.70.04) 1636
- Supercharger Outlet Pipe (18.50.16) 1825
- Intake Air Resonator 1818
- Thermostat - Vehicles With: Supercharger (26.45.07) 1593
- Coolant Pump - Vehicles With: Supercharger 1612
- ?SC coolant pump? 1616
- Accessory drive picture 1680
- Accessory Drive Belt - 4.2L SC V8 - AJV8 (12.10.40)
- Accessory Drive Belt Tensioner - 4.2L SC V8 - AJV8 (12.10.41) 1693
- Accessory Drive Belt Idler Pulley - 4.2L SC V8 - AJV8 (12.10.43) 1698
- Supercharger Belt Tensioner (18.50.24) 1703
- Supercharger Belt Idler Pulley (18.50.09) 1707
The following 4 users liked this post by No Quarter:
