Adaptive Headlight warning light
Today, all of a sudden, I had a flashing warning on the dash indicating a problem with the Adaptive Headlights. The lights appeared to be working fine and the warning eventually went off. I also notice that when turning the engine off, I always hit the lock button on the key fob twice. I used to hear a beep on the second push but that now beeps intermittently. When ever I experience gremlins like this, I start thinking battery. Thoughts?
Ah, headLIGHTS. Your Title had me going for a minute.
Anyway, I get that warning maybe twice a year. My foolproof solution... go out and give each headlight a couple medium but firm raps with your hand. Go back and shut down/restart your car. No more light! At least, that's MY experience.
I had the headlamp warning come up intermittently on mine. It is a known issue. It is mega-annoying because of the distraction when you are driving. It would happen then the next time I drove it it wouldnt, then it was happening a few times a week.
In the end the headlamp module was replaced under warranty which fixed it.
Ever since I read Cee Jay's quick fix of smacking the headlights a couple of months ago, I wondered if it really worked. Well, I can attest that I have received the adaptive headlight warning about 3 times over the last couple of months. Each time, I have gotten out of the car, hit the headlight with a flat palm, then locked the car with my key fob, and then restarted the car, and each time the warning has disappeared. If you fail to lock the car first to "reset" the systems, the warning will remain on. I tried without locking and the warning would not clear. After locking, it's gone. Thanks Cee Jay.
The following 4 users liked this post by tberg:
The following 2 users liked this post by McJag222:
chazaroo (08-15-2017),
Queen and Country (11-29-2018)
The following 4 users liked this post by pk4144:
Mine triggers with irritating regularity during the winter months when the lights are being used virtually every trip.
The flashing light on the dash is a real distraction and will most likely be covered with a small piece of black insulating tape this year as the lights seem to effectively work ok. My suspicion is that there's an occasional 'glitch' in one of the headlight assemblies that triggers the error.
Once the error is triggered the error light will not turn off until:
1. You have completed your current journey that triggered the error, and
2. You have then completed another journey after the one that triggered the error without another error being triggered.
So you need at least 1 completely clear cycle of ignition on/off before the light will turn itself off. When you start the car again, the light will have extinguished.
Hence the apparent 'smack the light' process above seeming to work. It's nothing to do with the smack, but all due to the cycling of an ignition on/off with no error.
The following 4 users liked this post by Cee Jay:
Interesting thread and thanks for the info. My 2009 XKR does this also and seemingly random. I agree that the light is annoying and distracting. Must remember to give it a smack ! It somtimes comes on when driving and then goes off with no smack, but maybe the potholes do the job for me !
Cee Jay (05-07-2021)
JagRag (10-08-2017)
