ADCM and ABS module reprogramming
Old 10-12-2013 | 07:08 PM
Ngarara's Avatar
Default ADCM and ABS module reprogramming
So, I've discovered that the Active Damping Control Module (which also controls the Electronic Active Diff) and ABS module (which also handles Dynamic Stability Control) on the XKR-S have different software and/or maps from the modules on my 75, though the hardware is the same. The Adaptive Dynamics settings were tweaked for the later car, and a bespoke software tune was created for EAD and DSC. Considered opinion from someone who knows is that the 75 would benefit from running the later software/maps.
Problem is, I haven't found anyone that can reprogram these units. Ideally, I'd like to download the software images and data from an R-S and flash that into my modules. It appears dealers may be able to flash the modules, but they (obviously) are unlikely to play along. I've spoken to a couple of aftermarket tuners, but they only deal with the ECU and its maps.
Does anyone out there know of a company that can do this stuff?
Old 10-12-2013 | 08:56 PM
DGL's Avatar
DGL
Tell the dealer you're experiencing some intermittent weird behaviour with your ABS brakes and e-diff and you'll like to have your ADCM and associated modules re-flashed. Let them know you'll like to see the technician and give him a VIN from an R-S to reference as the software update. If the technician questions you, give him $100. Get him also to re-flash your ECU if he can to boost your power to 550 hp. Getting to know your technicians and dealer service center can be helpful.
Old 10-13-2013 | 08:29 AM
Ngarara's Avatar
I don't really rate my local dealer - they're constantly telling me I need a service when I don't. And I don't think they're likely to play ball. Dealers in the UK are a bit nervous about skirting the rules; comes of being close to the mother ship, I guess.
I'll have a chat with my indy specialist - they might have the right tools. If they do, I'll find a local R-S owner that can help with a brain transplant…
Old 10-13-2013 | 11:51 AM
JagV8's Avatar
Probably IDS/SDD and a Mongoose JLR will do it - these are quite cheap to buy if you look, then it's DIY.
Old 10-13-2013 | 01:39 PM
DGL's Avatar
DGL
Can one flash the ECU this way to get an XKR-S tune if they have an XKR-S VIN?
bdboyle
09-16-2019 06:58 PM
NS2000XKR
01-01-2017 11:41 AM
millertic
09-30-2015 09:11 PM
leep123
09-30-2015 04:41 PM
Quick Reply: ADCM and ABS module reprogramming
