Adding a sensor to the front lower valance
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
aftre recently damaging the front carbon fibre valance, before I put another one on and do the same thing I was wondering if anyone else has done the same thing. To prevent this from happening again I want to add a sensor at this area and tie into the existing sensor harness from the bumper sensors. Has anyone out there done anything like this thanks
sherbercars (12-17-2017)
I don't think it's a huge deal. Just find a 12-24 vdc proximity sensor with the range you want and wire the switched leg into an LED on the dash.
It's actually easier to pick a spot on the ground or the vehicle next to you to stop at that gives you a foot of clearance up front. Figure 6' from the side mirror to the bumper lip so stop 7' from the end up the car next to you. Spatial orientation for the win.
Received 2,012 Likes
That said, you should be able to 're-locate' one of the front center sensors to that lower position. I wouldn't pull out an existing sensor, leaving a hole, but get a replacement sensor, place it where you want it, and then disconnect the donor sensor and wire the new sensor to the donor sensor connector.
Cheap-o sensors are all over Amazon and eBay. You can buy a whole system of four with the indicators for $12. Install them wherever you want.
https://smile.amazon.com/YueYueZou%C...parking+sensor
The following 2 users liked this post by Cee Jay:
kj07xk (12-18-2017),
iramphal
10-10-2017 09:37 AM
Boomer from Boston
07-17-2017 05:32 PM
