Advice needed for brake job 2009 XK
good morning folks, It's time to replace my brakes soon. I have a few questions for you veterans that have done this before.
1. Can the factory rotors be "turned" machined? Or do I need to replace them at each brake job?
2. Is there any special procedure when dealing with the rear E brake?
I am considering using a brake kit from Hawk Performance, has anyone had any experience with this company?
This is the specific brake kit I am looking at.https://www.hawkperformance.com/part...el=92594¬e=
At least to me , the brake change on the xkr was a straight forward , pretty easy job. Using a cheap $10 cylinder caliper compressor worked great , just keep on turning the cylinder with biscripts so it pushes down while applying pressure with caliper compressor.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
There is a service limit for rotor thickness. If they are at or below the service limit, they should be replaced.
If they are within spec and don't show signs of warping, then I would keep them.
If you undo the 2 bolts on the rear E-brake, you can split the caliper in half essentially and remove the rotor without having to mess with the cable or bolts going to the knuckle.
Be careful with the 2 pins and clip inside the e-brake when reassembling. And don't forget the e-brake reset procedure when you're done.
Both my '07 XK and my 2010 XKR are pretty simple to do, and without disconnecting the e-brake.
The piston retraction tool is imperative, but my local auto store lends them out with nothing but a deposit.
The rear e-brake takes a little manhandling, and un-mouning the bracket holding the end of the cable from the caliper. but it is pretty easy after yo have done it once.
Hawk is a highly respected company. Sadly they do not make brake pads for our cars, or I would be all over them!
badicedog (09-23-2019)
Ah well, ya got my hopes up again!
badicedog (09-24-2019)
venom_99
67
11-23-2012 12:09 PM
