Advice please on leaving OBD2 reader permanently installed
I recently bought an OBD2 reader for my XKR. I am loving the additional info it offers me (eg coolant temperature) but I am wondering if it is a good idea or a bad idea to leave the gizmo permanently in the OBD port? I am not so much worried about it flattening the battery as I always use a CTEK charger when the car is in the garage - but are there any other side-effects or negative consequences of leaving the OBD2 reader attached all the time? It would be good to hear from other members who have any experience of these devices. Thanks in advance...
The last time it stalled I had to disconnect the battery to bring the car back to life because it was totally dead which was a bit embarrassing because I was stopped at the traffic lights on a three lane, one way street and I was in the middle lane!
I have not had the same issues with my replacement dongle.
Not giving any reviews or saying if this one is good or bad, but it’s the one I bought and has worked for me without any issues...
I do think the product has a lot to do with it. How the line in the sand is drawn between good vs bad is vague, so I'd fall back to ones folks say work fine.... Mine didnt....
Myself and at least one other have had the bluetooth dongle crash the computer.
https://www.jaguarforums.com/forum/x...-kitty-126282/
I know mine was pretty cheap, but once I pulled it I remained problem free, and only use it for temporary diagnostics now.
BOL
BOL
Sean W (11-27-2019)
I left my inexpensive OBDII Bluetooth dongle plugged into my 2013 XJ and the next day when I started it my dashboard warning lights went bonkers. The car ran fine so I immediately drove to my Jaguar dealer and my service adviser told me to never leave it plugged in. I cleared all the codes and it never happened again.
It depends on the quality of the ODB2 device. My '07 XKR stalled a number of times and I eventually realised that it coincided with when I had the ODB2 dongle plugged in.
https://www.amazon.com/gp/product/B005NLQAHS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I assume this dongle is of sufficient quality?
This is the extension I bought:
Best, Keith
GGG (11-27-2019)
Just for clarity, I am not experiencing any issues with the BAFX dongle - just wanted to be sure it was OK to leave it permanently connected (power drain aside which isn't an issue for me). Seems to be variable experiences, based on the different types of dongle used. There is an amazing difference in price between the various options, which presumably is reflected in quality differences somehow? I have seen them advertised for as little as 5 dollars up to the (approx) 25 dollars I paid for mine. I chose the BAFX because other members had recommended it and because I ***-u-me that the higher price says something about the quality of the unit (not always the case, I know).
The only downside, so far, with the BAFX unit is its size. It's almost 3 inches long which means it sticks out quite a long way when it's plugged into the OBD port. I got around this with an extension cable (see earlier post) and can tuck it away somewhere less obtrusive now.
I have been using a Scan Gauge OBDII reader for the last several years. It is a code reader as well as the ability to read various functions of the car. I use it to do a live read of both Water temperature and battery voltage. It is a corded system so it is plugged in at all times. It also turns off after the car is locked so no battery drain. It has never triggered any codes and it serves it purpose for me.
Queen and Country (11-27-2019)
Thanks. I am using the BAFX dongle .........
To my surprise, see screenshot below.
Is that device not working well for you then? I *seem* to be having no issues (at the moment)....
