Advice please on leaving OBD2 reader permanently installed
1 out of 2 is I think, but never needed to use it again as a forum member gave me the perfect device.
It displays temp and voltage, and it has a auto power off chip.
For code reading there is better stuff anyway, much more detailed.
Not in a position to search at the moment but will post links if there is any interest.
Barnsie, bottom line is that if you're not experiencing any problems, go with what you have. looks like there's a mixed bag of results. Mine were in use for awhile before I started having problems but pulling it out, resolves it so don't sweat it imo.
barnsie (11-27-2019)
This was one of the models I had also that messed with my TPMS.
If I get any issues with the BAFX, I'll post them here.
We don't have laws about rear fog lights, but we have them thanks to the UK! (Sadly, idiot Americans are clueless, and abuse the use of them too! grrrrrr)
What? It has been law over here for some time! I guess I just figured since all cars sold in the US have them, that manufacturers would just make it standard across the board?
It's not just Americans who abuse rear fog lights. It's one of my pet hates here. At the first sign of the lightest mist, on they go. Even though you can see for 300 yards, on they go, blinding anyone behind. And then, when the mist clears, they forget to turn them off, so you're blinded again but this time without even a hint of a good reason.
Back to TPMS, my 2013 XF had it and I wished it hadn't. Seemed that if the pressure dropped by just one pound, the darn light would come on. Sometimes it would come on anyway even though the pressures checked out OK. The TPMS in my wife's Range Rover is similar. So in my 2008 MY XKR I'm kinda not really missing TPMS to be frank.
#28
TPMS is required in the UK (and EU) for cars from a date (2012 I think) but bear in mind that will tend to mean when a model is introduced.
Also, may well be another date for a truck.
Sadly some makers fit poor versions, giving TPMS a bad name when it's the car maker which ought to get the bad name!
My truck is the Mitsubishi L200 Barbarian (love that name) so although mine was new in 2018, the model has been around for years, so maybe that is why TPMS is absent (even on my top of the range model they didn't offer it even as an option).
#32
Anyway, interesting read here on TPMS mandate
https://en.wikipedia.org/wiki/Tire-p...itoring_system
#33
A little more on this thread hijack - TPMS was actually first adopted in European luxury cars. Here in the US it was mandated in part because of what's known as the Firestone/ Ford tire controversy. The problem caused several hundred deaths. Seat belts save lives, safety glass, air bags, Child safety seats, crumple zones etc. The list goes on - all government mandates. Not all government work is bad. Much of it is, but in this case, I'm with the safety nuts:-)
#35
Seems weird to me....
#37
2 years using the cheapest Bluetooth adapter on Amazon "Foseal". $10 Don't think I have encountered any issues related to it, and refresh rate seems to be fast.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
barnsie (11-29-2019)
#38
Well, that’s what my wife’s 2016 Mazda3 uses. When I went to buy a winter set of wheels and tires on TireRack.com, I couldn’t find TPMS for them to have them pre-installed by TireRack when they mounted the tires before shipping to me. Did some research, and was surprised that they use the ABS system to detect rotational speed differences between the wheels and an expected value for correct tire pressure (just in case all tires are equally low). You can reset the expected value if you change overall tire rotational distance. So no TPMS senders or sensors on her car, and it apparently satisfies the government watchdogs.
CleverName (11-30-2019)
#39
Weird it may be but is used by VAG (VW, Audi, Skoda, Seat, ...).
CleverName (11-29-2019)
#40
That shorter radius means that that wheel needs to rotate faster than the others, and the ABS system detects it.
The following 2 users liked this post by kj07xk:
CleverName (11-29-2019),
Queen and Country (11-29-2019)
