I was wanting to see if these alloys would fit
Concerned about the fronts due to the ET range.
Also a side question, can you put an 11J on rear? I know the XkR-S came with 10.5J. I really like the deep concave look on the 11J version of these alloys.
The short answer is yes you can use these wheels, but the measurements will have to be careful.
guy's link is helpful, and shows what the car came with from the factory, as well as a comparison tool.
The bolt pattern is 5 x 108. If the wheel chart you posted is correct, you won't be able to get 20x11 in that pattern.
I think a reasonable fit would be a 20x8.5 ET45 with 245/35ZR20 tire and 20x10 ET45 with 295/30ZR20 tire. That wouldn't exactly be factory setup, but the only risk would be 4mm slightly closer to the front fenders.
