Aftermarket Wheels?
Old 08-29-2020, 05:20 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
Default Aftermarket Wheels?
I had a flat yesterday and had to put the spare on. I was kind of embarrassed to drive it that way, but when I stood back and looked at it, the black rim actually looked GOOD against my silver car.
My existing rims have a little bit of curb rash on them, so I got to thinking about just replacing them with some aftermarket black rims.
Before I go any further, let me be clear. I don't want anything gaudy. I don't want to make the car look gangsta or ghetto. I just liked the look of the black rim against the silver car.
Which brings me to my question, doesn't Jaguar use a special bolt pattern? When I had my 2003 XK I remember people saying that it's hard to find aftermarket rims that will fit the bolt pattern.
Or... I could keep my existing rims and fix the curb rash using Chris Fix's method on YouTube, and just paint them black, but I think black rims look better with more space between the spoke so the calipers and rotors stand out
Old 08-29-2020, 05:30 PM
MarkyUK's Avatar
Lord forbid, what would your congregation think! Why not go for some black jag originals?
It's the PDC and offset your after which google shows me this link for:
Jaguar XKR Mk2 X150 06 on PCD Wheel Fitment | Jaguar XKR Mk2 X150 06 on Wheel Fitment Guide | Jaguar XKR Mk2 X150 06 on Fitting Guide
Personally the only aftermarket alloys I'd consider are Oz Ultraleggra;s as they look stylish and are light, but in 20's they are expensive!
PS: it probably helps to state the alloy size your after?
guy (08-31-2020)
Old 08-29-2020, 05:32 PM
Scott in PA's Avatar
What about having your rims refinished?
The following 2 users liked this post by Scott in PA:
guy (08-31-2020), V7Sport (08-29-2020)
Old 08-29-2020, 06:51 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
Check out https://w ww.coventrywheels.com/. They make several different wheels engineered for our cars.
Old 08-29-2020, 07:04 PM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
+1 on refurbishing your OEM Jaguar wheels in whatever shade of black you prefer. You're in NC, so I suspect that there are several shops in your area where you can stop in, see the work that they do, and decide on a color.
Old 08-29-2020, 09:48 PM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
Although I think the Senta rims were the nicest look on the XKR, my car came with Kalimnos, which I painted black against my liquid silver with red calipers showing through, and I still like it seven years later. (Although cleaning brake dust is not my favorite chore)
gkubrak (08-30-2020)
Old 08-29-2020, 09:53 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
One hint, although some people will frown for no reason.....
Get two extra rear wheels and put them on the front. They fit great with a 3mm spacer and then you won't need spacers and you won't mess up your scrub radius.
Old 08-30-2020, 12:45 AM
Dcdeuce's Avatar
Tberg you are so right! Although I just got my car I've been shocked at how quickly those wheels get covered in brake dust!!!! But they sure do look good in black!
Old 08-30-2020, 10:24 PM
JAL's Avatar
JAL
JAL is offline
Off topic...where did you get the R performance badge for the lower rocker panel?
Old 08-31-2020, 06:17 AM
MarkyUK's Avatar
It pays to clean your wheels off the car thoroughly, anti ferros treat, wax and polish and then apply some gtechniq C5 wheel armour:
https://gtechniq.com/products/auto/p...5-wheel-armour
I also changed my pads to ebc reds with lower dust when I had my wortec discs/rotors fitted, but any that is created rinses right off with a hose, every 6-8 months I clean and top up the ceramic coating with this stuff:
https://www.iodetail.com/products/ca...4aArRxEALw_wcB
So they still look like this 20 months later:
Old 08-31-2020, 06:33 AM
Impressive! Would it make sense to apply this wheels off, and treat the inside walls of the rims as well?
Old 08-31-2020, 06:40 AM
MarkyUK's Avatar
Initially yes off the car, my paint correction/detailing guy took the wheels off in Nov 18 and did the insides
I've not taken them off since but drive up my ramps to clean the very inside and apply my reload product.
If you are having your tyres changed then it's also an ideal opportunity to clean if you've got a friendly tyre changing place. So I get them to take the first wheel and tyre off, I clean and seal the first whilst they move onto the second.
Old 08-31-2020, 08:56 AM
80sRule's Avatar
I recommend refinishing your factory alloy wheels. They are of very high quality and unlikely to go egg shaped or have other issues. If you like the design but want to add pops of color or do a blacked out look, those wheel refinish guys are SUPER used to doing that. If you say you want the barrels to match for a color change they absolutely will do that too (for extra cash). My wheel guy is awesome, and for a factory color redo, he's about $100 a wheel, more if you change color and want the barrels to match. Outstanding work too, and to my understanding, $100 a wheel is pretty standard pricing.
If you go to a mobile wheel refinisher, they recommend having the tires you want on the wheels. The paint is soft for a month or two. So if you want new tires or they are coming up, get them done first or wait a while. The good wheel guys will mention this though.
Old 08-31-2020, 11:20 AM
tberg's Avatar
JAL,
I am assuming the question about the R performance emblem on the back of the rocker skirt is for me. One day while picking up some parts from Chris at Mina, I saw these sitting on a table at his shop. I had wanted to add a bit of color to the sides to break up all of the silver and had considered a red pinstripe. When I saw these sturdy badges, I asked Chris if I could buy them, but he just gave them to me instead. I still like them, they're subtle but give a hint of color.
V7Sport (09-01-2020)
Old 08-31-2020, 05:19 PM
JAL's Avatar
JAL
JAL is offline
tberg, yes it was sorry if that wasnt clear, still a newbie at this. I have similar color car as yours, silver so i really liked they way these stood out.
Do you have a way to send me any info on how I can get two? Not sure who Mina is....LOL.
They look great on your car.
Old 08-31-2020, 05:52 PM
tberg's Avatar
JAL,
I live within a few minutes of Mina, so I can stop by in the next day or two and see if he still has them. You can google his website: Mina Galleries and is located in Reseda (Los Angeles), CA. Chris is very personable and answers his own phone if you call him. There are many items that don't appear on his website.
Ted
Old 08-31-2020, 06:24 PM
guy's Avatar
guy
guy is offline
Received 1,123 Likes on 791 Posts
Show us @Cee Jay !
Old 08-31-2020, 07:22 PM
Cee Jay's Avatar
Originally Posted by guy
Show us @Cee Jay !
Yeah, well, I just did the technical measuring and such. I've not gotten any yet, although I DID buy some. Had to cancel the order because they shipped the XF offset wheels and not the XK ones.
Here's what you would get though, 3mm spacer, or even a 5mm spacer.......
Front Tires will be 19mm farther out from stock, but also 5mm farther IN, so that right there would negate 95% of Scrub Radius problems. Instead of having 20mm farther out and another 20mm farther out on the INSIDE..... that makes a mess. Plus, fatter tires on the front with a bigger dish just LOOKS so..... much..... cooler........
Old 08-31-2020, 07:42 PM
Cee Jay's Avatar
New sizes for the rears also, to fill out the fenders...........
And if anyone noticed, the backspacing for this "new" wheel is the same as the OEM fronts......... just the width is larger by 1.5 inches.........
Old 09-01-2020, 07:30 AM
JAL's Avatar
JAL
JAL is offline
Tberg...thanks for the info, I went to the website and they are advertised for sale. I will reach out later today.
Thanks for the help!
Jim
Quick Reply: Aftermarket Wheels?
