Air Conditioner Leak. (Should I just drill a drain hole in the passenger footwell?)
No, in another thread it was stated that the duckbill design changed part way through the 2010 model year. A 2010 owner found that the hole is covered but there was a seam that he was able to pull back the insulation to get in. The hole is dead center over the transmission, 5-6 inches back from the front of the firewall.
https://bringatrailer.com/listing/2011-jaguar-xkr/
Received 2,190 Likes
I just did jackjohns XKR a couple weeks ago. yes you will break off the egr coolant tube if you don't unbolt it. Or you can drop the front subframe down and the trans and you wont break it. either way the R's are much harder than the NA engines.
Mbeyda1
02-26-2015 04:30 PM
Leonard_85
11-15-2012 02:19 PM
