Air conditioning barely blows, and just in a certain temperature range
#41
I have fairly short fingers, but isn't it supposed to stick out from that hole?
On the attached drawing, which is the actual positioning of the thing? A or B?
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/775x262/duck_8f6b10bc37f5195126a5978b0e949dfbe8aff641.png)
Thanks!
#42
Received 2,011 Likes
#43
The bottom of the picture therefore corresponds to the direction of the bottom of the car.
So taking this into account, is it still the B configuration?
#44
#45
Just to clear any potential confusion: the black "L's" (and inverted L's) in the drawing all represent the sides of the hole where the duckbill is located. The inverted L on the left of A & B is not the transmission.
Here is a lengthy thread on the topic:
https://www.jaguarforums.com/forum/x...lution-149349/
#46
#47
#48
That's precisely what puzzles me...your above pic suggests configuration "A" in my drawing (see post #41), with the duckbill even sticking out...which I could not feel at all.
However, in the last pic of this pdf it definitely looks like configuration "B", with the tip being horizontal and pointing forwards : https://www.jaguarforums.com/forum/a...ion-ac-fix.pdf
Can it be different from one model to the other?
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
#49
#50
this has been a nightmare for me, good luck to you, for most people it is as easy as replacing the resistor or fan, I have put them in and out multiple times on my xk trying to test why its still not working, so it shouldn't be that bad to do it once, the glove box is easy to remove, just unplug all the connectors, and then the actual motor and resistor is 2 screws for resistor and 3 screws for fan, no dash removal for this.
NTL1991
XJ40 ( XJ81 )
10-28-2013 09:37 AM
