Air in Cooling systen
You really need to vacuum fill the coolant on these cars. I did mine the old way, relying on gravity but the IAT always read higher than usual. I bought a vacuum bleeder and bled it, IATs dropped more than 25 degrees after vacuum bleeding.
If you don’t have the tool, disconnect the two pipes on each side of the charge cooler and leave them disconnected until coolant starts to flow from them, then reconnect. Start the engine and let it run till the thermostat opens. Keep checking the level and top up as necessary.
‘The vacuum bleeders are around $80 on Amazon for a decent one and well worth the money in my opinion.
Racer343
01-06-2012 11:40 AM
blaksplash
86
06-20-2011 05:14 AM
