Airbag light on B0002-1B
Hi
I have a 2007 XK and getting a constant airbag light on I have already tried
1. Car has new battery and is fully charged
2. Cleared the fault it comes straight back
3. Took front drivers seat out and disconnected all the plugs sprayed them with electrical contact cleaner
could this be the clock spring? Or something else
thanks in advance for any thoughts or suggestions
@Ajmanning68 Welcome to the Forum. You'll find lots of knowledgeable and helpful members here. But you need to help us to help you by creating a signature and completing your Public Profile, as detailed in this thread:
https://www.jaguarforums.com/forum/n...-up%2A-241802/
Regarding your airbag warning light, don't guess. Always search this Forum first, before doing anything else. The X150 is almost 20 years old, and almost every question you can think of has already been asked and answered. Here's the answer to your question:
See Post #16, by Forum Moderator GGG:
https://www.jaguarforums.com/forum/x...solved-246884/
How did I find that? It's easy, if you know how to do it. Read this:
How To Find Answers To Your Questions
Stuart
Stuart
Hi Stuart,
Thanks I have updated my signature. I should have mentioned I had scanned the forum and looked at the possible solutions hence I had gone through checking the connections under the seat and clearing the fault using an icarsoft device but still no joy as it just comes back as soon as the car gets to about 10 mph
Regards
Adrian
Regards
Adrian
You can download the service manuul here:
https://www.jaguarforums.com/forum/x...guides-215509/
It will steer you in the right diection.
So just wanted confirm that I replaced the Clock spring and it has resolved the airbag light on issue. The removal of the airbag was the hardest part of the process I used a screwdriver and an adjustable spanner on it to give leverage to turn the screwdriver and pull the airbag out.
Thank you everybody for your input
Sean W (08-12-2024)
JoonasJaguar
07-20-2024 06:28 AM
