Greetings All,
just had my spring alignment done. What could be the cause of the misalignment on the rear right?
Taking away the obvious for you
-factory suspension arms installed and in good order.
-factory bushings installed and in good order
-rims not bent
-all tires high speed balanced.
I know this issue very well. Changed a rack, all of elements - no luck. Ended with an adjustable rear upper wishbones.
Pros - I have an alignment as from a factory
Cons - ride quality is rather hardcore (but I believe it will help with handling very very much), especially with my Korean antiroll bars on poli-bushes
In case an alignment wins - can help arrange a set of them (custom made in Poland).
