All Aluminium Radiators?
I managed to find a builder that can make a radiator for my XK, but the question about transmission cooler came up, and Im wondering if any of you have any input in this.
One of the options is, to gut my oem radiator and use the stock cooler, but Im curious about external coolers and if this would be a better option on my base 2007 x150. Ideas are all welcomed!
Interesting question, hope someone has experience there.
I would think a radiator shop would have no problem building a Trans cooler into a radiator these days. Its pretty common, and parts to do so should exist? Of note, if I were to have a custom built unit, I would do some serious measurements and see if there is room for an additional core on the front side.
Vince
Vince
I've had both brass and aluminium radiators built for the various engine conversions I've done. Most shops can build anything that you want but I wouldn't believe there is anything special about the XK unit. Also my bet is they can fix the one you have . The easiest thing to do with most builders is to bring them the original unit and have them replicate it. As for the trans cooler I would believe it would be better to have it built in and the same size/volume as OEM. You may not have enough room for an external mount and it may interfere with the AC condenser.
Queen and Country (01-13-2019)
I agree that I should stick to the oem design. So I will have the radiator made and use the stock trans cooler within the newly built unit. My goal is to rid myself of a plastic topped radiator.
No such thing as an 'over cooled' engine. Not now, not ever... Engineers can only dream of such a possibility. All police vehicles in the U.S. use oversized radiators and have for 30+ years. That's why they can sustain high speeds for significantly longer than any base OEM.
As I said, measurements would be everything. If it is impractical, so be it, but I wouldn't miss the opportunity to upgrade it it could be done.
Vince
Vince
Vince
Vince
Clever, I agree that Improved Cooling Capacity is a good thing. That would also include a properly operating thermostat.
JackJohn (01-15-2019)
Prange (01-15-2019)
What keeps me trucking forward with all aluminium is that I can have it made for less than an oem. Original dimensions is probably best for me on this first try. I still think plastic is a cost effective way to mass produce 10s of 1000s of units to meet manufacturer demands. They have a lifespan, that doesnt meet my expectations for a car that I drive a lot in extreme temps 6-7 months of the year.
Cee Jay (01-15-2019)
AW2Jaguar
04-04-2016 10:37 AM
