Alpine Amp and Woofer Question Please
And what manufacturer is that? You may PM me if you prefer, one of my many sources of income is from over 20 years in pro & CE audio design & integration...
jahummer (05-18-2016)
You won't get it from the head unit as this is a MOST system, with digital signal going through a DSP and then digital to the amps. Your best bet would be to get it from the line level signal at the driver. Your new power sub maybe able to take this directly or you may need a speaker level to line level adapter, found all over the net.
#28
#30
hi. i'm wanting to replace the crappy woofer in the alpine sub/amp combo in the passenger foot well. does anyone know what ohms the amp puts out, so i can chose the right speaker (if i can find one that even will fit). wondering if a 4 or 8 ohm speaker is needed. i don't have a meter to check, so was hoping someone would know before i have to buy one or borrow one. tnx.
Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker
13mm excursion with Neodymium, 38Hz free air.
Tang Band W6-1139SI 6-1/2" Subwoofer
The compliance on these work well with 50W RMS.
cyber3d
04-22-2016 01:52 AM
papalarge57
04-21-2016 10:59 PM
daves_ale
04-20-2016 08:45 AM
