Alternative wheels for a XK-R
Only 3 more sleeps before I collect but a question about wheels.
I have been contacted by someone with a set of Vortex wheels from and XK-RS
for sale.
They are very slightly wider than the wheels on mine I think by half an inch front and rear. Will they fit ok?
for sale.
PsiFox,
You're in GB and I think that the Vortex wheels you described may be from a 4.2L 2008 XK-RS, which was a special edition not available in the USA. If so, the rears won't fit your 5.0L 2014 XKR. The electronically controlled limited slip differential was introduced with the 5.0L models, and that caused the rear wheel offset to change from the 4.2L models. I believe that the front offsets are the same.
Vortex wheels were introduced in the USA beginning with the 5.0L models and have the correct offsets to fit your 2014 XKR. The design is identical to the Vortex wheels on the UK-only 4.2L XK-RS except for the paint color. I think, but am not certain, that the 2008 4.2L Vortex wheels were forged and that the 5.0L wheels are cast alloy.
Stuart
Stuart
PsiFox (05-21-2017)
PsiFox (05-22-2017)
