Aluminum Replacement for OEM Plastic Coolant Pipes
Was there ever a follow up to this?
Also, is there a parts list floating around for replacing coolant hoses and gaskets on a 5.0 S/C engine?
I'd like to put an order in with the dealer and want to get all the correct parts in one order.
Keep in mind I already have aluminum outlet tubes installed on my engine, so likely I'll keep those and just replace the o-rings.
So far, it's looking like the following are needed (if outlet tubes are being replaced as well):
Can anyone tell me what additional items I'm missing, if any?
Do any of these items need more than 1x pcs?
Do any of these parts come included with a higher level assembly, such as gaskets with the water pump? I don't want to waste money on duplicates.
- Outlet tubes (AJ813865, AJ813917)
- aluminum or plastic parts available
- Outlet tube o-ring 3x (AJ811350)
- This is because I have aluminum outlet tubes, so I'll just replace the seals.
- Supercharger gasket (AJ811948)
- Intake manifold gaskets (AJ811576, AJ811590)
- Heater manifold (AJ814007)
- Oil cooler o-ring (AJ811539)
- Oil cooler pipe (C2Z18658)
- Could include o ring
- Coolant tube (C2Z28258)
- Coolant hose (C2Z26930)
- Plug - blank (JDE33172)
- Heater manifold gasket (AJ811600)
- Is this included with the heater manifold?
- Oil cooler gasket (AJ811904)
- Recommend to replace since it's accessible
- Water pump (AJ813909)
- Replace while it's accessible.
- Could include gaskets
- Water pump gasket (AJ813609)
- Included with water pump?
