Am considering r/r my front upper control arms...will the strut removal be a bear?
As the title states...I am starting to look at refreshing my front suspension. I am chasing a mild knock in the front right (right now it is a modest thunk) and I see the rubber is coming apart slightly. I am approaching the r/r of the upper control arm as a pretty basic job...but after reading several other posts, I am starting to worry I may run into issues.
I see I need to remove the strut. Is it enough to remove the lower bolt and the upper three to free it up enough for me to access the upper control arm bolts? Or, will I need to remove the lower suspension as well (I hope not?)
Okay, the right side is done. Coolant tank was an interesting burn of 2 hours. I am now of the opinion that the hose clamps that come OEM are too big a pain to deal with. I kept them...for now.
Tomorrow I do the left side. Hope that is smoother. Biggest issue thus far is finding the correct torque settings. I think everything in the front suspension is 70nm.
Thanks all for your responses.
Front Suspension Torque Values from Workshop Manual
Sean W (04-27-2024)
bgpenguin21 (04-28-2024)
Klooney
05-14-2021 08:43 AM
forrestgk
04-01-2021 09:55 AM
