AM Radio stopped working!
Open the boot and pull out the right hand side vent as you look in. You'll now see a small module bolted to the inside boot panel, that's the AM/FM splitter. Check to see if the connections on it are ok and the fakra cables are still connected, this maybe the cause of the problem. If you have the electric aerial, water can get past the seal around the aerial and could damage that splitter.
Ozmag (03-21-2017)
Just had a look and everything connected fine - mine is 08 so dont have the electric aerial
Mike
7500ftJagGuy (08-24-2024)
7500ftJagGuy (09-16-2023)
Are you getting static or nothing?
Does the system allow you to select the AM band and the stations and you get (what)?
Are you getting any DTC's?
Some information on your system:
The MOST network if failed would impact both bands.
On all vehicles from 08MY, the AM/FM antenna is located in the rear spoiler. The antenna has a hardwire connection to the amplifier which is mounted on the inner Left-Hand (LH) side of the lift gate, behind the trim panel. The amplifier is held in place by a steel strap. The amplifier is connected to the integrated audio module, via the FM antenna signal splitter, by a coaxial cable.
Control signals from the integrated control panel (Your push button display) are relayed on the medium speed CAN (controller area network) bus to the information and entertainment module (which is located behind the touchscreen). The information and entertainment module relays the control signals to the rest of the audio system on the Media Orientated System Transport (MOST) ring.
The source button on your steering wheel allows you to cycle through CD/ AM/ FM etc....
So Antenna, amplifier, integrated audio module, steering wheel control and clock spring.
A DTC is a Diagnostic Trouble Code which would be thrown if you had issues with your systems.
If you attempt to switch media from say FM to AM using the steering wheel control and then also using the touch screen and you have the same problem in both instances, I'd call a local AM station and ask them if they're aware of a more global problem.
Do you have AM @ home or in another car?
OK well if friends are having the same problem than it appears to be tower transmission issues, not likely car related.
Sean W (08-13-2021)
Hey don't knock it I have an 8-track in my basement that I had in my 63 Corvette. Got a dozen or so tapes too. Hahahaha
Given that you have friends who also lost it at or near the same time, and they're not all driving Jags making this this worlds largest coincidence, I don't see how it could be vehicle related. But I'm still curious to know what you find out.
