AM Radio stopped working!
#61
IAM Module
I am hesitant to go into to the Jaguar agency as they seem to do more harm than good. My 07 Coupe has been absolutely brilliant and remarkably trouble free. I will order the module from the parts department and seek a competent technician to attempt the swap. The thought of messing around with the electronics is really frightening however I would like to have the car back to it's pristine condition. I keep thinking I should sell it while its working perfectly but the beauty and performance is compelling. Let me know if you resolve your issue, I appreciate you taking the time to respond.
Big Mike
Big Mike
#62
Same issue on '07 XKR THANKS ALL
Thanks to everybody for putting all the info. together in this thread.
When I started reading I didn't even know where the active radio unit is in the vehicle. It all works fine save for the AM radio. It went intermittent but very quickly died altogether. I now propose to dig the module out of the car (when the weather improves) confirm the part number and source a replacement.
Garry near Manchester UK
#64
Since I have somewhat poor FM reception as well, I am tempted to swap out the antenna or booster. But have not pulled the trigger.
#65
Maybe, and maybe not. I tried replacing my IBOC with a used on on ebay. It didn't change anything. So either the replacement was also defective, or that was not the issue.
I wonder if that applies to you and I.
I also wonder if this can be fixed out of warranty...
#68
#71
You won't get any module codes from a generic reader, you need SDD. Some pricey good ones will read Jaguar codes also, but SDD was built for Jags, so it's the gooderest one to use.
guy (08-14-2021)
#72
#73
