AM Radio stopped working!
Old 10-15-2019 | 10:14 AM
big mike's Avatar
Default IAM Module
I am hesitant to go into to the Jaguar agency as they seem to do more harm than good. My 07 Coupe has been absolutely brilliant and remarkably trouble free. I will order the module from the parts department and seek a competent technician to attempt the swap. The thought of messing around with the electronics is really frightening however I would like to have the car back to it's pristine condition. I keep thinking I should sell it while its working perfectly but the beauty and performance is compelling. Let me know if you resolve your issue, I appreciate you taking the time to respond.
Big Mike
  #62
Old 01-04-2020 | 12:53 PM
Garry Grigg's Avatar
Thumbs up Same issue on '07 XKR THANKS ALL
Thanks to everybody for putting all the info. together in this thread.
When I started reading I didn't even know where the active radio unit is in the vehicle. It all works fine save for the AM radio. It went intermittent but very quickly died altogether. I now propose to dig the module out of the car (when the weather improves) confirm the part number and source a replacement.
Garry near Manchester UK
  #63
Old 08-13-2021 | 01:43 PM
Samets's Avatar
I have poor FM reception to the point where radio station identifiers are not filling in. On any given day I might be able to catch 2/3 FM stations. Same 7W93-19C034-AE module to blame?
  #64
Old 08-13-2021 | 02:44 PM
MurrayG's Avatar
Maybe, and maybe not. I tried replacing my IBOC with a used on on ebay. It didn't change anything. So either the replacement was also defective, or that was not the issue.
Since I have somewhat poor FM reception as well, I am tempted to swap out the antenna or booster. But have not pulled the trigger.
  #65
Old 08-13-2021 | 03:39 PM
Samets's Avatar
After some digging, I found this: https://workshop-manuals.com/jaguar/...dio_reception/
I wonder if that applies to you and I.
I also wonder if this can be fixed out of warranty...
  #66
Old 08-13-2021 | 03:46 PM
MurrayG's Avatar
Interesting! If the cable (and connectors) are readily available, it would be worth trying.
Thank you!
  #67
Old 08-13-2021 | 07:39 PM
guy's Avatar
guy
the first step is to read the codes. the fix may be as simple as a module refresh.
  #68
Old 08-13-2021 | 08:38 PM
MurrayG's Avatar
Yes, absolutely. Owning a jag, the first thing I bought was a code reader. It gets regular use. Sadly, the audio system is throwing no codes.
Excellent advice though.
  #69
Old 08-13-2021 | 08:51 PM
Cee Jay's Avatar
Do you use SDD, or some other reader?
guy (08-14-2021)
  #70
Old 08-13-2021 | 11:02 PM
MurrayG's Avatar
Just a standard, generic one.
  #71
Old 08-14-2021 | 12:44 AM
Cee Jay's Avatar
You won't get any module codes from a generic reader, you need SDD. Some pricey good ones will read Jaguar codes also, but SDD was built for Jags, so it's the gooderest one to use.
guy (08-14-2021)
  #72
Old 08-16-2021 | 09:51 AM
Samets's Avatar
Is this something only dealers have?
  #73
Old 08-16-2021 | 10:40 AM
V7Sport's Avatar
No, Some Indy shops will have it. Or you can make your own with a laptop, interface cable and software. See the sticky’s section for SDD background.
