Another Dyno day tuning session new record! Hit 453 to the wheels on 4.2 aj34s
Old 10-16-2019, 01:26 PM
XJR-99's Avatar
Originally Posted by kj07xk
Sounds like you live in California.
When I look out the window it looks like I am in Alaska. At least we have same latitude.
  #42
Old 10-17-2019, 01:04 PM
AlexJag's Avatar
Sponsor
Xjr-99 that's sounds like Europe
"If the car feels like a catapult and goes 9.9 - then everything is fine "
Time slips are good but really there is no more acurate tool than a Dyno to measure hp gain. Way too many variables on track , just with Density Altitude alone difference, same car can be 1 sec slower with identical track conditions but different Density Altitude
  #43
Old 10-17-2019, 01:50 PM
jahummer's Avatar
Received 2,383 Likes on 1,493 Posts
I‘m guessing Finland...
  #44
Old 10-22-2019, 07:33 AM
Aarcuda's Avatar
Well looks like I will be looking for a safe tune once i get my injectors back in and it all put together. these numbers are impressive and i already have the upper pulley installed
  #45
Old 10-23-2019, 04:37 AM
XJR-99's Avatar
Next week, if there is no snow, we go to dyno. 8h of dynotime reserved. WOT needs to be fully tuned from scrach. We use 93 + water/meth at this time. Next year most probably E85 / C85. .
  #46
Old 10-31-2019, 05:19 AM
XJR-99's Avatar
  #47
Old 10-31-2019, 12:48 PM
AlexJag's Avatar
Sponsor
So what where the numbers?
That's some serious boost....
  #48
Old 10-31-2019, 12:52 PM
Cee Jay's Avatar
Received 5,511 Likes on 3,242 Posts
25 PSI is huge for a Roots SC, or is that Turbo piping I see there?
  #49
Old 10-31-2019, 05:35 PM
viper1996's Avatar
If I run someone from a start, 1/4 mile or 60 roll and I beat them I could care less about there dyno horsepower...Here are my dyno results: I estimated my HP with my mods and fluff it up by 50 HP and that's MY dyno number, and no one questions it or asks to see dyno sheets...
  #50
Old 10-31-2019, 08:04 PM
AlexJag's Avatar
Sponsor
Good for you ! So if you beat a Corvette with your Civic your going to estimate your power based on your win! Good Science
  #51
Old 11-01-2019, 01:25 AM
1 of 19's Avatar
Why does every thread involving a tune seem to go South?
  #52
Old 11-01-2019, 06:49 AM
viper1996's Avatar
400 horsepower to start at the crank.. supercharger pulley 75...cold intake 100... K&N 25...flap removal 30 pretend I got a tune for another 30 it adds up fast🙂 That comes up to 660 magically becomes wheel horsepower When anybody asks... I do have the dyno sheets but the dog ate them if anyone asks😉
  #53
Old 11-01-2019, 06:54 AM
Canadacat's Avatar
Alex Jag you should get someone with a 5.0 to dyno on the same machine as you, that would be your proof of H.P.
  #54
Old 11-01-2019, 08:34 AM
XJR-99's Avatar
t's not roots SC - It's a twin-screw (TS) + all kind of goodies. Today the car passed special inspection and the mods are official and legal. Here you can't bolt what you want to provide as much power as possible. You have to be able to provide signed dyno document, which includes all parameters and the power has to be lower tha maximum power per weight. Of course with tuning you can show almost anything you want by modifying just a few parameters and without changing any parts.
  #55
Old 11-01-2019, 01:01 PM
AlexJag's Avatar
Sponsor
I got plenty of proof have no reason to think numbers are off . Dyno matches other cars that were on it with modifications perfectly. Pre mod Dyno numbers are there. At same track racing my friends on regular basis , car with an identical launch is dead even with stock 550hp cts-v , and beats stock Xlr-V with 440hp by nearly a second . Plenty of other cars on the list to verify the numbers...
  #56
Old 11-01-2019, 01:03 PM
AlexJag's Avatar
Sponsor
Xjr-99 Total different ball game your playing there. But since you pushed it to 25 you did check max power right?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
  #57
Old 11-02-2019, 07:05 AM
XJR-99's Avatar
We had just four hours time to make basic maps. Timing was very, very mild to get power enough low. Every single degree made about 20hp difference and we were more than ten degrees from optimal level. Cam timing is not optimal for high revs, LSA is too narrow. The engine makes massive middle rev torque but most probably too narrow LSA to rev well over 6K. We have 106.5 / 113.5 - should be 110 / 118 with those cams ( best LSA for positive displacement SC is about 114-116 )
  #58
Old 11-02-2019, 09:51 AM
viper1996's Avatar
Alex what are your AFRs?
  #59
Old 11-04-2019, 11:51 AM
AlexJag's Avatar
Sponsor
It's in the Dyno graphs above. Around 11.5 at WOT
viper1996 (11-04-2019)
  #60
Old 11-04-2019, 11:59 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
Wrong thread....
Quick Reply: Another Dyno day tuning session new record! Hit 453 to the wheels on 4.2 aj34s
