ANOTHER TPMS Info Request
I know there are other threads on this subject, and I did go thru several. Here's what I'm wondering about, car is a 2007 XK: When I start the car, I get the single TPMS yellow light, goes out immediately. I have another set of wheels/tires that I'm going to put on the car, wheels are from an XJ, probably 2007-2011. I mounted one to see if the sensor would be recognized. Started the car, display was normal. Took a short drive, maybe 1/4 of a mile, all seems normal. I dropped the pressure down to about 20PSI, and no TPMS warning light. So, if the batteries are shot, would I still get a steady light or no light at startup? Since the TPMS light comes on at startup, does that indicate the batteries are good? TIA
A TPMS SYSTEM FAULT displayed means that something else is wrong.
Joe,
You're in Philadelphia. Take your XK to any national chain tire retailer and ask them to scan all 4 of your tires for the remaining life of your TPMS batteries. Note the MaxiTPMS battery testing tool used by the technician at 1:51 of this YouTube video.
If any TPMS sensor has a low battery, you should replace all 4. Use only the OEM VDO/Continental 315 Mhz sensor, which needs no programming. Check prices on Rock Auto and your local auto parts stores.
Stuart
Stuart
Cee Jay (01-02-2024)
SonofGaladriel
11-15-2021 10:33 AM
tiger_reddy
07-22-2018 02:23 AM
